Narrow vs Wide trac - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-06-2002, 06:31 PM Thread Starter
Tippy's Avatar
Narrow vs Wide trac
Ok dumb question. I know the width difference between a narow and a wide track CJ axel, but what else is there? Do the shocks mount up differntly? I am thinking of swaping axels and I would like to make a wide track set so I can swap them into a newer jeep if I ever need to. I know this would change steering parts, but what else?
Tippy is offline
post #2 of (permalink) Old 09-06-2002, 07:55 PM
Re: Narrow vs Wide trac
I have a wide trac jeep that I'm rebuilding and I also own a 74 CJ-5 (obviosly with a narrow trac) and I haven't torn that one down but I do think that the shocks mount in a different spot, I would definetly look further into it before swapping, but all in all, if you can weld up a new shock bracket then there should be nothing to it.
CJ7Attitude is offline
post #3 of (permalink) Old 09-06-2002, 08:08 PM
I don't know if it follows wide/narrow exactly, but on my '80 the front shock's lower stud is on the spring plate and on the '85 it is on the axle. The '85 has longer shock towers on the upper end.
80sCJ7 is offline
post #4 of (permalink) Old 09-07-2002, 06:45 AM
The wide track axles have the lower shock mounts welded to the axle. The narrow have them as part of the spring mount pad. I'm going to use the anti-roll bar so I bought spring mounts with studs for the shocks and the links. The shock mount locations are close and the same height(use '79-shorter shocks) so I'm eyeballing it and I think the two won't interfer. If so I will just cut and grind off the axle mountings. The only steering parts that are different are the rods, they are both longer. I have 2 wide track axles painted and sitting in the garage that are going under my Jeep in the spring. I'm collecting parts through the winter.
JimmyZ is offline
post #5 of (permalink) Old 09-07-2002, 10:58 AM
Official Historian
WILL's Avatar
Wide tracs also use 5 bolts to hold the lockout while the narrow use 6 bolts. If you are swapping, use the 6 bolt hubs.
WILL is offline
post #6 of (permalink) Old 09-07-2002, 03:35 PM
Drury's Avatar
If you are going from narrow to wide and have the 6 bolt narrows, swap from the knuckle out on the fronts and the backing plate out on the rears. This will get you the bigger brakes front and rear.
Drury is offline
post #7 of (permalink) Old 09-09-2002, 06:37 AM
I don't think the brake size change coincided with the axle width change. My '79 has the small brakes on the narrow axles. Double check the brake size first.
JimmyZ is offline
post #8 of (permalink) Old 09-09-2002, 07:13 AM
Big brakes were an option in '78, and it was probably the same in '79. What you find will be a matter of blind luck.
Jim_Lou is offline
