Power steering seal ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-06-2002, 02:23 PM Thread Starter
Tippy's Avatar
I did a search and everybody says that it is easy to change the input saft seal on my CJ's p/s box. I removed the box from the Jeep to get a better grip on it. My question is how do I remove the seals? The pitman arm seals were no problem, but the input shaft seals are confusing me. It looks like I need to unscrew the large retaing ring w/ two little holes in it to replace an o-ring that came in the rebuild kit. If so, what is the best method? Do I need a special tool or can I do it with a puch and hammer? The instructions in the rebuild kit are terrible. Thanks.
Tippy is offline
post #2 of (permalink) Old 09-06-2002, 02:38 PM
Official Historian
WILL's Avatar
Re: Power steering seal ?
I changed this seal years ago on my pickup. It has the same saginaw gear on it. You'll need to get a repair manual that shows how to adjust the steering gear. After you remove the gear from the frame, there is a large lock ring that you remove. Next, you'll need to unthread the valve spool. This will require a spanner wrench. I made a tool to do this job. I had a 2-1/2" socket that I cut a peice of plexiglass into a hex shape to fit into it. Then I drilled two holes in the plexiglass and inserted some machine screws that fit the holes in the valve spool. This also let me use a torque wrench on it when reassembling it.
Be very carefull when unthreading the valve spool that while unthreading it, you keep pressure on the input shaft. If this shaft pulls back, all the recirulating balls fall to the bottom and you'll have to get farther into the gear than you want to. (Learned that one by accident. After I got it together, I had to take it back off for some reason and forgot to hold the shaft. All the balls went "plink, plink...")
Another option is to just replace the whole steering gear with one from a parts store. Last fall I replaced mine with one from a 70's camaro. The box is the stronger one with "76" cast on it. It was $115 for me.
WILL is offline
post #3 of (permalink) Old 09-06-2002, 05:44 PM Thread Starter
Tippy's Avatar
Where can I get a copy of the repair manual? Does anybody have it on file?
Tippy is offline
post #4 of (permalink) Old 09-07-2002, 11:05 AM
Official Historian
WILL's Avatar
Try your local library. I've been in a couple that have Mitchell manuals. Since they are in the reference section, you'll have to make copies though.
WILL is offline
post #5 of (permalink) Old 09-07-2002, 12:50 PM
Hooch's Avatar
I am in the same boat!! Same seal is leaking on mine after my last off-road outing....
Check your PM's
Hooch is offline
post #6 of (permalink) Old 09-07-2002, 05:48 PM
jps4ever's Avatar
If I remember right, you have to count the turns while unscrewing valve spool and be sure to put it back in the same amount of turns.
jps4ever is offline
