how quick can a driveline vibe cause damage? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-05-2002, 09:09 PM
chrisd0729
I have a slight vibe after installing the 4" lift and I'm waiting for RE to send my t-case drop. Is it ok to drive with the vibe for a couple days or can the vibe really do damage that quick? It's only a slight vibe while accelerating above 30+ mph and as soon as I let off the gas it stops.
If it's ok to drive a little bit, is it ok to do hiway speeds so I can take it to work 1 day?
TIA
post #2 of (permalink) Old 09-06-2002, 06:13 AM
Re: how quick can a driveline vibe cause damage?
A slight vibration isn't going to cause any damage. You probably have a problem from the U-joint axes being out of parallel. That vibration will be causing cyclic load changes on the gear teeth in the transfer case and differential. It would take a long time for that to damage the gears.
Jim_Lou is offline
post #3 of (permalink) Old 09-06-2002, 07:38 AM
Official Historian
WILL's Avatar
And please fill in your profile.
WILL is offline
post #4 of (permalink) Old 09-06-2002, 10:56 AM
Bryan's Avatar
I drove a couple hundred miles with a bad rear shaft vibration and I think it made my rear diff seal leak.
Bryan is offline
