Axle swap questions - 70's wagoneer - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-04-2002, 05:27 PM Thread Starter
Axle swap questions - 70\'s wagoneer
Do all 70's wagoneer's come with 20 in the rear? Or did some come with Dana 44's front and rear? I'm having a hard time finding some 3/4 - 1 ton chevy axles, so I'm thinking of going with some wagoneer axles instead. I've found some 1/2 ton chevy axles but they're double the wagoneer's price. Would I have any trouble with the wagoneer axles if it had the 20 in the rear?
(I'm putting in a Dana 20 transfer case so the front differential is swapping sides.)
muddog is offline
post #2 of (permalink) Old 09-04-2002, 05:29 PM
Re: Axle swap questions - 70\'s wagoneer
no amc 20s in the rear of 70s Jeep full sizes.
BUt most are offcenter for the Qtrack transfer case. good luck finding a rear centered dana 44
all late 70s wagoneers had dana 44 rears, and dana 44 fronts.
the latermodels 1980 and later used amc20 rears, and they are just as strong as the rear dana 44s
ozarkjeep is offline
post #3 of (permalink) Old 09-05-2002, 09:27 AM
Official Historian
WILL's Avatar
The late 80's and early 90's were back to dana 44 rears though, right?
WILL is offline
post #4 of (permalink) Old 09-05-2002, 10:26 AM
Zombie
And don't forget that majority of the waggies from '74 to '77 had the flat topknuckles.
post #5 of (permalink) Old 09-05-2002, 06:00 PM
jeepgod's Avatar
1970 and older fronts are D27's p.o.s.
1970-1973 D44 front closed knuckle p.o.s. 5 lugs
1974-1977 D44 front open knuckle passenger side drop with flat top knuckles 6 lug
1977-1979 D44 front open knuckle passenger side drop 6 lug
1980-1991 D44 front open knuckle drivers side drop 6 lug
1970-1973 D44 rear center diff 5 lug
1974-1979 rear d44 most are off set for the quadra trac/center diff's came with T-18's 6 lug
1980-1986 rear amc 20hd center diff, 1 piece shafts & thicker tubes than the cj version 6 lug
1987-1991 rear d44 center diff 6 lug
jeepgod is offline
post #6 of (permalink) Old 09-05-2002, 10:26 PM
Official Historian
WILL's Avatar
That holds true for the 73 and older FRONTS, but the 70 to 73 rears are centered 44's with 5 on 5-1/2" wheel pattern and 30 spline shafts. I had one of these in mine until a local shop "worked" on it and ruined it.
WILL is offline
