Gear setup necessary after axle housing swap? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-29-2002, 08:19 AM Thread Starter
TOM85CJ7's Avatar
Am I correct in assuming that it is not necessary to re-set gears if all you are doing is a housing swap? I can check everything to be sure, I am just curious about how much time to allow when swapping complete ring/pinion/case to another housing.
Thanks,
Tom
PS This is for swapping Narrow-trac parts to wide-trac housings.
TOM85CJ7 is offline
post #2 of (permalink) Old 08-29-2002, 08:30 AM
Re: Gear setup necessary after axle housing swap?
It should be close. You will have to check the pattern. Start with the shims that were in the old housing in the same order and check. I've seen it go both ways.
AllLockedUp is offline
post #3 of (permalink) Old 08-29-2002, 08:50 AM
RatPatrol
I just replaced my D44 housing after bending an axle tube and breaking the pumkin housing. Everything went back together fine, I checked the gear pattern and had a professional double check it. It should be fine but always a good idea to double check, especially in a rear axle.
Good luck,
-Jeremy
post #4 of (permalink) Old 08-29-2002, 10:24 AM
I would think if anything is off it would be backlash, easy enough to check.
post #5 of (permalink) Old 08-29-2002, 10:25 AM
its dependant upon the machinging tolerences in teh housing it self.
to be safe check it, the later AMC years are probably closer to one another than the early years as production techniques and equipment got better.
ozarkjeep is offline
post #6 of (permalink) Old 08-29-2002, 11:04 AM
Official Historian
WILL's Avatar
Or worse as it wore out.
WILL is offline
post #7 of (permalink) Old 08-29-2002, 12:24 PM
Official Curmudgeon
CJ7Taz's Avatar
I don't know a lot about this subject, but I do know that if the number of faces on the pinion has a common divisor as the number on the ring, you have to put them back the same way. For instance, if the ring and pinion are both even, the odd faces on the pinion never come into contact with the even faces on the ring. They develop different wear patterns and will cause problems if not reinstalled in the same relationship.
I would suspect that the tolerances would require it to be reset.
CJ7Taz is offline
post #8 of (permalink) Old 08-29-2002, 01:56 PM
MaineJeep
I haven't actually done this myself, but it seems like the pinion depth is dependant on the housing. The shims are to position it from the bearings to the offset marked from the centerline of the ring gear.
post #9 of (permalink) Old 08-29-2002, 03:11 PM
Tom, Since the machining tolerences of the housing can affect all, preload, backlash and pinion depth, going from one housing to another, I would do a complete setup. Your current shim stacks should be a good starting point. Taz also makes a very good point. You should mark your set for proper re-alignment when removing from old housing.
RocknCJ is offline
