some help and questions please.
Ok i'm rebuilding a 81 CJ 7, i'm taking out a GM crate 350, SM 465, NP 205, some one had put in it. so if you wana buy it lemme know via E-mail.
i'm putting in it a 258 from an 84. what i need are the motor mount brackets, the ones with the 3 bolt holes to bolt to the engine then to the motor mounts. and not a junk yard one has them around here or they wana sell the hole engine with them.
so, might any of you have them lying around, or know where i can buy new/used ones.
second,
locker in the front or the rear.?
Rear- bad tire wear, chirp tires, harder on driver train, hardly ever need 4x4.
Front- not hard on drive train, hard to turn, pulles up hills better than can be pushed up them, realy bad driving on slick roads.(i think) in the winter time.
anyhow please some insite would be Great
thank you
HR.
