Header collector flange warp, cure on Trucks! ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-29-2002, 12:38 PM Thread Starter
My 3-bolt header collector flanges are warped, so I blow out gaskets.
A buddy of mine told me they showed a cure on Trucks! a few weeks ago...
He said they showed a 3-piece flange, maybe 1/2 inch thick. Each end of each piece was drilled, then relieved on opposite sides for a flush overlap at each bolt hole.
He did not catch what company sold these.
Has anyone here seen/used these products?? Know where I can find them? A search on Summit and Jegs failed to turn them up. I sent an email to TNN, but I figure they won't answer.
It sounds like a good cure, which is just what I need before I do something I'll regret with the sawzall and welder... [img]images/icons/laugh.gif[/img]
Let me know if you have any info on these.
lynn is offline
post #2 of (permalink) Old 07-29-2002, 12:45 PM
mbalbritton's Avatar
Re: Header collector flange warp, cure on Trucks! ?
I had the same problem, but another cure. When I pulled my exhuast to drop the bell housing and tranny a couple months ago i found a blown collector gasket and didn't have a spare. my buddy (who owned the shop we were in) grabbed this black sealer that he uses, basically Gasket in a tube. holds up to Super high temp. ran a bead, no more problems. Stuff comes in a pressurized can so it comes out like cheese whiz. Runs about $10 a bottle. DAMN good stuff! I use it on diffs, ccollectors, heads, anyting that needsa good seal.
Brent
mbalbritton is offline
post #3 of (permalink) Old 07-29-2002, 12:57 PM
Pooh-Bah
WD40's Avatar
Re: Gasket Sealer
Permatex makes it.
It's called, <a target="_blank" href=http://www.permatex.com/products/prodidx.asp?f_call=get_item&amp;item_no=25223>The Right Stuff</a>.[img]images/icons/wink.gif[/img]
WD40 is offline
post #4 of (permalink) Old 07-30-2002, 09:21 AM Thread Starter
Re: Gasket Sealer
Thanks for the input guys. I may go that way if I can't locate another fix.
Didn't anyone see this portion of Trucks! ? Maybe my buddy John is pullin my leg... [img]images/icons/wink.gif[/img]
I've made a rough drawing of what I want, I'm going to talk to a couple machinist friends if no one here has a solution...
lynn is offline
post #5 of (permalink) Old 07-30-2002, 09:40 AM
Re: Gasket Sealer
That's not the one he had, but I'm sure it's basically the same stuff. I'll See if I can fiind out what he uses. I'll be up at his shop Wed. working on the PS on the CJ.
Brent
post #6 of (permalink) Old 07-30-2002, 10:20 AM
Lynn I thought it was on Horsepower TV, not Trucks. Either way, I did see it and they looked like a great idea. Unfortunately they don't keep info about the products very long on their websites. It does seem though that they repeat the same shows quite often, so maybe you can catch it.
post #7 of (permalink) Old 07-30-2002, 10:27 AM Thread Starter
Thanks Snowtow. I'll check with a local speed shop, maybe they've heard of it.
lynn is offline
post #8 of (permalink) Old 07-30-2002, 11:31 AM
TOM85CJ7's Avatar
If you can tell me the broadcast date, I can probably figure it out. Was this on Horsepower TV?
Later,
Tom
TOM85CJ7 is offline
post #9 of (permalink) Old 07-30-2002, 11:35 AM
TOM85CJ7's Avatar
Found it!!
It was on Trucks.
Here you go:
http://www.truckstv.com/truckgear/vi..._date=07/20/02
Later,
TOM85CJ7 is offline
post #10 of (permalink) Old 07-31-2002, 09:42 AM Thread Starter
Thanks Tom!
I'll check it out.
Meanwhile, a buddy on another board found a site with a slightly different solution:
www.headerbudy.com
It's now being marketed by www.jonesexhaust.com
(click on new products)
Sounds like there's a couple solutions out there...
Thanks for the input!!
lynn is offline
