throtle cable for 350 swap? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-28-2002, 12:26 PM Thread Starter
ok im trying ot figure out what to do about a throttle cable for a 350 swap with an edlebrock 1400 series carb. i tried drilling out the opening in the stock cj7 throttle cable end but it ended up breaking off after pumping the gas a few times. what do yall with 350's use?
lifted95z71 is offline
post #2 of (permalink) Old 07-29-2002, 04:32 AM
tys
Re: throtle cable for 350 swap?
good question. one that most who've done the swap don't answer. I'm in the middle of doing this swap and wonder the same question. From what i'm told, most guys use the cable from the vehicle the engine came from. for instance, if your tree-fiddy came from a camaro, try to use the cable from the camaro, and go from there.
btw, what did you use for radiator and hoses?
Chris
tys is offline
post #3 of (permalink) Old 07-29-2002, 07:09 AM
I just did this swap w/ a tbi motor. I used the original cable from a 1/2 ton truck. I had to cut the end (at the pedal off) and use an aftermarket cable clamp to get the length right, but it works great. Just make sure you get the clamp tight enough that it won't slip when you mash the gas. I set mine to have just a little slack at idle, and it'll still pull the throttle all the way open when you floor it.
HTH and good luck!!! [img]images/icons/cool.gif[/img]
Bald_One is offline
post #4 of (permalink) Old 07-29-2002, 10:54 AM
tys
Thanks. I will head to the junk yard to grab one soon.
Chris
tys is offline
post #5 of (permalink) Old 07-29-2002, 11:08 AM
Or call your local chevy dealer... I only paid about $12 or $15 for mine new
Bald_One is offline
post #6 of (permalink) Old 07-29-2002, 12:14 PM Thread Starter
i got a mepco 3 core radiator. from mepco4x4.com i think. as far as hoses i went to advnaced and they said they can almost certainly have a has somewhere that will fit. of course they say losts of stuff like that.
post #7 of (permalink) Old 07-29-2002, 03:24 PM
I'm confused?
Will the cable not fit on the ball or will are there other problems?
If it wouldn't fit on the ball, you can buy new throttle balls or whatever from oreillys for cheap.
JoeyCJ55 is offline
post #8 of (permalink) Old 07-29-2002, 09:46 PM
I used a lokar from summit
ducmon900 is offline
post #9 of (permalink) Old 07-30-2002, 03:21 AM
tys
You went where for hoses? Advanced Auto? What did they tell you? Your message is confusing.
Chris
tys is offline
