Re: Heater!!
[img]/wwwthreads_images/icons/crazy.gif[/img] Jeep Girl, this is crazy....my 1987 thru 1995 Jeep Wrangler book shows the same heater that our '79 CJ has??? How can this be?? The blower works through a resistor which is under the glove box, and has three wires plugged into it. BLK TAN and LG (whatever that color is). The motor plug is under the hood on the diagram, under the battery, like the CJs have it. If the blower switch is on High, ther resistor is out of the loop so that eliminates the resistor as a suspect. Find the under hood blower...pull the wire off and check for current....if no current...check fuse (25 AMP) So there are two switches...the heater switch, and the heater SPEED switch. The orange wire should be plugged into the speed switch. [img]/wwwthreads_images/icons/wink.gif[/img]
CJDave
