Question about Rocker Panels - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-26-2002, 06:56 AM
Hey all....just wondering if anyone knows if it would be cheaper to have a sheet metal shop fabricate me a set of rocker panels as opposed to buying them from somone? I would of course have the shope use 3/16 metal....
Jim
post #2 of (permalink) Old 07-26-2002, 07:59 AM
Re: Question about Rocker Panels
Search this forum, this has been discussed here ad nauseum. Most of us have used 1/4" 4x4 angle iron. A set you make yourself will cost you about 20 bucks.
post #3 of (permalink) Old 07-26-2002, 09:31 AM
Did that search on the rockers....great looking job....I'll be calling around Monday to get the iron after I measure....will most likely have them cut the ends underneath at 45degrees at the shop since I really dont have a decent shop at home setup....YET! Should I go with 3/16" or up it to 1/4"? The next part will be a dumb question, but if I go with a 6" x 4" piece of iron, I take it the 6" goes on the outside of the rig?
Thanks!!!
Jim
post #4 of (permalink) Old 07-26-2002, 10:13 AM
The concern with any modification is weight. 6x4 is overkill, and extremely heavy. I have 2x4x3/16" for mine, and they take all the bashing I can dish out. The angle is mounted with the short leg on the bottom. This configuration has more than enough strength, in fact I wish I would have used 1/8" for them. The only weak part is if the jeep were to be t-boned, the lighter metal and shorter leg has a smaller bending moment. In that instance, other problems arise, eliminating the benefits of the rockers anyway. For wheeling my lighter rockers are great and help to prevent overloaded components.
jfralph is offline
post #5 of (permalink) Old 07-26-2002, 11:07 AM
2"x4"x3/16" sounds like the way to go....it's been awhile since I've handled any angle iron....guess I'm forgetting how heavy that stuff is....
Thanks for the advice!
Jim
post #6 of (permalink) Old 07-26-2002, 11:49 AM
If you do any serious rock crawling 1/4" is the way to go. Not that significant difference in weight, big difference in strength.
post #7 of (permalink) Old 07-26-2002, 12:18 PM
Brad....
How do feel about the 2"x4" size of angle iron?
post #8 of (permalink) Old 07-26-2002, 02:12 PM
I think that would be just fine running the 2" underneath. But, the 4" provides a better surface to slide on, and anyway, I couldn't get the 2x4 here!
post #9 of (permalink) Old 07-26-2002, 02:13 PM
Thanks!!! Pretty sure I'm going to go with the 4x4 then....makes sense about the underside....
Jim
post #10 of (permalink) Old 07-26-2002, 04:04 PM
-snip-6x4 is overkill-snip-
I guess I have no idea what overkill is,,,,,,, mine are closer to 6x4 feet [img]images/icons/smile.gif[/img]
W.C. is offline
