Line lock - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-22-2002, 10:28 PM Thread Starter
86CJ7's Avatar
Line lock
Anyone know of a line lock that can be used as an emergency brake? I would like to find one that does not need constant voltage to keep it locked.
86CJ7 is offline
post #2 of (permalink) Old 07-23-2002, 06:45 AM
Re: Line lock
Yes they are made. I think J.C. Whitney has them. They are a lever type that you can mount on the dash but they have to be plumbed. They work the same in that you set the brakes with the normal foot pedal then flip the lever to keep them on whatever axle you have them set up for.
JimmyZ is offline
post #3 of (permalink) Old 07-23-2002, 10:16 AM Thread Starter
86CJ7's Avatar
Re: Line lock
The JC Whitney one is a manual switch. I would prefer to find an electronic one. Anyone know of an electronic one that will work?
86CJ7 is offline
post #4 of (permalink) Old 07-23-2002, 10:23 AM
Re: Line lock
I don't understand. In your opening post you said you didn't want an electronic one. Aside from that a line lock should only be used as a temperary parking brake. not as an emergency brake and certianly not while winching. Not Safe.
Loafer409 is offline
post #5 of (permalink) Old 07-23-2002, 10:34 AM Thread Starter
86CJ7's Avatar
Re: Line lock
I don't think my first post said I did not want an electronic one. You may want to read it again. I said I don't want one that needs constant voltage to keep it closed. I am looking for one that can be activated by a remote switch to lock and unlock it and when locked does not draw from the battery.
86CJ7 is offline
post #6 of (permalink) Old 07-23-2002, 10:55 AM
Re: Line lock
Okay. I don't know of any that work like that.
Good Luck
DSD
post #7 of (permalink) Old 07-23-2002, 11:23 AM
thorjeep's Avatar
Re: Line lock
I have been looking into line locks for some time now (intend on putting them in Thor for a 3rd-foot).
However, all the electronic manufacturers say they are not safe for > 20-30sec. The solinoid will overheat and fail. They would be great as brakes, but alas, no one makes electronic ones. The only solution would be to convert a manual to electronic with a servo or something, though I wouldn't entirely trust that either.
thorjeep is offline
post #8 of (permalink) Old 07-23-2002, 11:32 AM
Re: Line lock
"However, all the electronic manufacturers say they are not safe for > 20-30sec. "
Did you mean 20-30 min. 20-30 sec seems unreasonably short.
I remember, years ago, in the service, my M62 Wrecker had an electronic line lock that I used to leave on for an hour or more routinely. Never did hurt it.
DSD
post #9 of (permalink) Old 07-23-2002, 11:37 AM
thorjeep's Avatar
Re: Line lock
They said seconds. Maybe Tractor equipment is different, didn't look into those.
thorjeep is offline
post #10 of (permalink) Old 07-23-2002, 01:35 PM
Journeyman
gmoabrim's Avatar
Re: Line lock
I'm using an electric actuated brake lock made by Mico back in the mid 80's. Their web site doesn't show it so I imagine it isn't made any more. This unit used a pressure switch similar to the old time brake light switches. You would flip a toggle switch applying power to the pressure switch, press on the brake pedal, the resulting pressure would actuate the switch sending power to a solenoid actuated valve in series with the brake line trapping the fluid and applying the brakes. Releasing the brake pedal would remove power from the circuit but leave the brakes applied. To release the brakes, flip the power switch to off, press hard on the brake pedal and the pressure in the system would equalize, releasing the brakes. I realize this is a piss-poor explaination as I'm going by memory. I have the instructions at home somewhere but as mentioned earlier, I don't think it is made any more. I'll try and find the info tonight and re-post.
Gary
gmoabrim is offline
