Ignition problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-05-2002, 07:09 PM
Ignition problem
I have a 1982 Jeep CJ5, straight 6. When the ignition is left on without the motor running for about 20 minutes the ignition coil and the ignition module burn out. In the last year I have gone through 5 of each. What could be the primary cause? It also did it once with the motor running in low gear.
Thank you for any advice you can give.
post #2 of (permalink) Old 07-05-2002, 08:36 PM
Re: Ignition problem
Do a search on this, it was covered not too long ago.
AllLockedUp is offline
post #3 of (permalink) Old 07-06-2002, 06:13 PM
OK, here we go one more time...
(This is the guys first post, I smell bait...)
FILL OUT YOUR BIO!
Why are you leaving the key switch in the 'Run' position without the engine running?
Do you know you can turn the key backwards for an 'Accessory' position, and it won't kill your ignition?
Do you have 12 volts at the positive terminal of the ignition, or around 8 volts? (resistor or no resistor)
You should have a resistor wire from the factory.
If you don't have a resistor, and are getting a full 12 volts to the coil, you can install an ignition resistor in the positive wire to the coil and stop this problem. Auto Zone (Wells) p/n F799 is what the factory uses, or you can use a pot type resistor...
We need to know if you have done the ignition upgrade?
Using the E-core coil or the stock coil?
Have you spliced in a good ground wire to the module black wire?
_____________
Stop buying crap parts,
Get the module from someplace like NAPA where you can get a Borg-Warner, and don't forget to splice into the black wire from the module and run a ground directly to the battery or primary ground wire. This will ensure a good ground for the primary ignition system.
Get a good coil, like Borg-Warner or MSD. Make sure the engine (especially the heads) have a good ground. Don't rely on the little crappy (or missing) 'Engine ground' strap, or the alternator to ground your secondary ignition system.
______________
Modules crap out because of too much current draw (dead grounded when the ignition is 'On' but the engine isn't running...) through the coil and bad module grounds.
Coils fail because of over heating when you are setting with engine not running, but the ignition is 'On', and when the secondary voltage has no where to go, like when the heads don't have a good ground.
Junk Yard Genius is offline
post #4 of (permalink) Old 07-07-2002, 08:29 AM
Thanks Aaron, I couldn't remember the exact causes of the problem but I knew it had been discussed recently.
Newbies, please heed this advice: there is a search feature on the board. Please use it! 99% of the questions asked here have been covered at one point or another, especially electrical/ignition problems. TeamRush is one of the most knowledgeable members of this board but gets frustrated answering the same question over and over. If you have done a search but couldn't find the answer, please say so in your posts.
