How do I remove the Windshield Sprayer Nozzle? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-04-2002, 01:06 PM
I have a 79 CJ7. I would like to ensure that the spray nozzle will work when I get a new pump for the washer fluid reservoir. It looks like the sprayer is made of brass, so it will score easily if I use a wrench. In any case, does it simply pull straight up and off or does it unscrew or is it permanantly fastened to the front of the tub?
post #2 of (permalink) Old 07-04-2002, 01:10 PM
Re: How do I remove the Windshield Sprayer Nozzle?
Stick your arm up under the cowl and there is a nut on the underneath , its a toughie to do but its possible . Its getting the wrench up there that can be an issue .
What I would do before you take it off is grab the hose up under there and just blow through it with some compressed air first , you might not need to remove it .
Jeff
Jeepzilla is offline
post #3 of (permalink) Old 07-04-2002, 01:13 PM
Jeepzilla - You mean from inside the Jeep right?
post #4 of (permalink) Old 07-04-2002, 01:18 PM
Yes , sorry if I wasnt clear on that . Up under , behind the dash at the very top . Grab the hose from the washer tank and blow through it first and see if its free before you go through all that [img]images/icons/smile.gif[/img]
Jeff
post #5 of (permalink) Old 07-05-2002, 11:08 AM
Hank's Avatar
I have an old Chevy truck that when i bought it the spray nozzles were less than perfect. I bought some CLR remover (Calcium, Lime, Rust) like you clean fixtures with that are exposed to hard water. I attached the hose feeding the spray nozzle to a syringe filled with CLR and kept squirting it out until it was easy to do.
What a difference it made - a lot of crud was stuck in there!
Hank is offline
