best way to cut aluminum diamond plate? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-03-2002, 12:52 PM Thread Starter
Drury's Avatar
I've got some aluminum diamond plate corners that I want to use to mount up some round LED tail lights. I've only done some minor work with aluminum before and couldn't get it very clean as compared to steel. Any ideas on the best way to trim and cut circles in this stuff cleanly?
Drury is offline
post #2 of (permalink) Old 07-03-2002, 01:14 PM
Pooh-Bah
pbmcauliffe's Avatar
Re: best way to cut aluminum diamond plate?
For my LED tailights I used a hole saw, I have also cut them with jigsaw and air saw with metal blades.
pbmcauliffe is offline
post #3 of (permalink) Old 07-03-2002, 06:22 PM
A hole saw is your best bet.
Get one with big teeth. Use plenty of cutting fluid and turn the tool slowly. Checker plate is usually dead soft. As such, the chips will load up the teeth. The cutting oil helps prevent that, as does backing the tool out every few seconds and blowing or bruishing the teeth clean.
Another good trick is to drill the pilot hole with a regular 1/4" bit, and put a piece of plain 1/4" rod in the hole saw arbor as a guide instead of using the drill bit they supply. Plain rod is a little stiffer, and won't enlarge the hole as a drill bit can. If you can get a piece of 1/4" drill rod to use, that is better yet.
Jim_Lou is offline
post #4 of (permalink) Old 07-03-2002, 06:33 PM
jamgood96's Avatar
I've also heard about putting some bar soap on the blade of whatever you're using to cut. Aluminum is real soft, and clogs up the blade easily.
jamgood96 is offline
