Need Some help with steering!!!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-02-2002, 11:27 PM
This steering system on my cj5 is driving me crazy!!! Ok, I have replaced the steering box and that was a job and a half. Anyway, now I can bearly steer right, and on turing left I have a of turing but when I turn or try to turn right I cant. I need some help! What can I do?
Thanks,
Chris
post #2 of (permalink) Old 07-02-2002, 11:39 PM
Re: Need Some help with steering!!!!
Did you bleed the system?
post #3 of (permalink) Old 07-03-2002, 08:00 PM
I couldnt bleed the system, it is manual steering. But, I am thinking about converting it to power. Did they make CJ5's with power steering?
Thanks,
Chris
post #4 of (permalink) Old 07-04-2002, 02:57 AM
yes they did come with power, on most things I would say don't give up and just replace it, but power steering such a plus off road.
Tony
tonyscj5 is offline
post #5 of (permalink) Old 07-05-2002, 09:03 AM
Bill4x4
Just a thought, did you get the box in the center of its turning range before you hooked up your pitman arm with the tires point to the front?
post #6 of (permalink) Old 07-05-2002, 10:46 PM
I had the tires centered but I dont think the box is. But, if I center up the box then the tires go out. And, the pitman arm is lined up on the shaft with the center marks. It there an adjustment on the link that goes from the pitman arm to the bellcrank? Because if there is, could I just adjust that?
Thanks,
Chris
post #7 of (permalink) Old 07-08-2002, 09:01 AM
Official Historian
WILL's Avatar
Sounds like the old ross steering gear with the bell crank. Do you have two short tie rods?
WILL is offline
post #8 of (permalink) Old 07-08-2002, 09:17 AM
I agree sounds like Ross box steering. If you are thinking of a lift, give it up till you change the steering, your nightmares only will get worse. I recently did the same on my Jeepster and can be done pretty inexpensively.
bigcheese is offline
