Need more gear setup advice - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-29-2002, 03:57 PM Thread Starter
GreenMachine's Avatar
I got some new bearings and honed them out (I was using the old bearings I had pulled off the carrier and they were slightly tweaked). I believe my pinion is too shallow right now. I did get the backlash set to about a 10 average (thousandths). Here are the pictures
This is a dana 44 5.38 factory gearset (new) BTW.
TIA
GreenMachine is offline
post #2 of (permalink) Old 06-29-2002, 08:33 PM
pontiac58's Avatar
Re: Need more gear setup advice
That looks better. Yeh do what you said you were going to do and get those clean patches evened up in the middle.
pontiac58 is offline
post #3 of (permalink) Old 06-30-2002, 08:39 PM Thread Starter
Here are two more.... I have screwed with this thing all day and this is the closest to centered I have got.... It's .002 from being too shallow or too deep. Please say it looks acceptable or I am going to chuck it in the lake [img]images/icons/laugh.gif[/img]
Seriously though... Does it look ok? This is a front end.....
post #4 of (permalink) Old 06-30-2002, 10:10 PM
I just finished regearing my front and rear, and am by no means an expert. With that said, your pattern looks great to me, if your backlash is ok! Good Luck!
OregonSahara is offline
post #5 of (permalink) Old 07-01-2002, 08:07 AM
pontiac58's Avatar
As long as your back lash is 8 to 10. Your good to go there. That pattern looks really really good.
post #6 of (permalink) Old 07-01-2002, 12:10 PM Thread Starter
The backlash is an average of 10....11 in places and 9 in others. The only thing l am not sure on now is the pinion preload. I tightened the nut down to about 85 ft lbs which gave me a drag of about 20-25 inch lbs on the yoke nut (the book suggested 14-19 inch lbs on new bearings but my inch lb wrench only goes down to 20). For final tightening it says 250 ft lbs but if I tighten it down that much my preload is gonna go way up.... What is the trick to this? Put more shims on the pinion shoulder infront of the rear bearing? I added .003 like the book sugested to compensate for settling bearings. I don't want the bearings screwed up but if I leave it at 85 lbs tight will that be enough (with lock tight or course)? Hopefully after I get this one done I will feel confident enough to do the next one without pestering (maybe not though as it has a crush sleeve). TIA
post #7 of (permalink) Old 07-01-2002, 07:07 PM
pontiac58's Avatar
Crush sleeves are 10 times easier.
Before you go nuts you may want to get a better inlb wrench. You want one that you can read down into the single digits. You may be getting a reading of 20 but you may only have 10. Your guage only goes down to 20 and probably isnt accurate at all down that low.
