spare carrier on bumper question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-28-2002, 04:46 PM
sas87yj
yeah i did a search but no find answer
will fab a carrier on my home-built bumper. will use some stout 1-1/2" tube that i picked up at my local welding shop.
question- what can i use for the pivot-point or hinge mechanism if you will? then i also need to figure out a latch device to keep it closed. i'm sure i can come up with something but your idea might be better [img]images/icons/smile.gif[/img]
any pics?
post #2 of (permalink) Old 06-28-2002, 05:15 PM
Re: spare carrier on bumper question
The ultimate hinge is available from rockstomper. It's a machined axle hub. The cheap solution would be to use solid bar stock for the pin and tubing for the pivot. That's what I am doing right now. If your bumper is already painted you could use a 1 inch bolt instead of welding the bar stock. Just remember to grease heavily. There are plenty of latches on mcmastercarr.com. The cheap way is a large bolt with bar stock welded to the top to make a T shape. You can screw it down tight by hand and it won't rattle.
post #3 of (permalink) Old 06-28-2002, 05:29 PM
For the hinge, goto http://www.carrlane.com/product/06TC54.htm
I used the middle latch for mine. Everything seems to work fine, but they are going to get tested this weekend.
TJ
teejay68 is offline
post #4 of (permalink) Old 06-28-2002, 05:36 PM
sas87yj
yo nenofury
thanks for the rockstomper tip- here's the <a target="_blank" href=http://linkhttp://www.rockstomper.com/catalog/pieces/hinge.htm>linkhttp://www.rockstomper.com/catalog/pieces/hinge.htm</a>
i'm not quite getting the install of it though. i have a 2x6 tube bumper. i need to either weld a pivot to the top of the bumper OR drill a hole in the top and bottom of bumper and feed a long bolt through. not sure the rockstomper will work for me?
post #5 of (permalink) Old 06-28-2002, 05:41 PM
sas87yj
tjay
looks like the latch has to attach to the end of the bumper and not the top?
post #6 of (permalink) Old 06-28-2002, 06:39 PM
Yeah you are going to have to drill holes in the top and bottom of the bumper. This is probably the hardest part since you have to keep them in perfect alignment. Yeah, with a 2x6 bumper the rockstomper won't work as it is only 8inches overall. Looks like a rod or bolt is your best bet.
post #7 of (permalink) Old 06-28-2002, 08:39 PM
sas87yj
yep
i be going the CUSTOM fab all the way on this one looks like [img]images/icons/smile.gif[/img] thanks for the insight
post #8 of (permalink) Old 06-28-2002, 08:45 PM
jamgood96's Avatar
I just ordered a hinge from Rockstomper. I know it won't work with your application, but I'd be more than happy to let you know how it works, or give you some specs so you can build a similar one.
jamgood96 is offline
post #9 of (permalink) Old 06-28-2002, 08:51 PM
sas87yj
thanks jammy
i think i got it now after seeing what's out there on the market. i can make a set-up just as good if not better. i'll weld a bolt to top of bumper and weld a sleeve at end of carrier to slide down the bolt.
post #10 of (permalink) Old 06-28-2002, 09:21 PM
jamgood96's Avatar
How does that latch attach? Any pics?
