Weber Carb intake modifications? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-28-2002, 01:40 PM
Greetings, I have a weber carb on a 84 CJ-7 with a 256. I'm concerned about water intake into the rectangle filter that came with the carb. Does anyone know any ideas on how to shield and/or relocat the air intake for this type of carb? Thanks, Kryptonic
post #2 of (permalink) Old 06-28-2002, 01:42 PM
Re: Weber Carb intake modifications?
<blockquote><font class="small">In reply to:</font><hr>
<hr></blockquote>
1) It's a 258 CID, unless you got jipped.
2) The filter is a K&amp;N style gauze filter, properly oiled (you can use the K&amp;N kits for this). It will keep most water out.
3) If you wish to relocate it, weber makes a cover you can use to connect it to a snorkle or use one of the tubes like TJ's do.
<a target="_blank" href=http://www.collinsbrosjeep.com/images/hardparts/weber/Flyer%20DGV%20Snorkel%20kit.htm>http://www.collinsbrosjeep.com/images/hardparts/weber/Flyer%20DGV%20Snorkel%20kit.htm</a>
4) Much easier and cheaper solution: use a set of your wife's old panty-hose as a prefilter, they will keep water out.
bluseman2a is offline
post #3 of (permalink) Old 06-28-2002, 02:15 PM
well....here's an idea for ppl with limited sheet metal skills. take a piece of .040 aluminum, (steel would be better) about 12" square, take the bottom plate and trace out the carb opening in the center and cut it out. use this as a heat shield or splash shield. you could bend the edges and make it a tray. if you really wanna be cheap, im sure you could use a small cookie sheet with the lipped sides. drill a few random holes for drainage. and that should do it. the only thing i can think of that would be a negative, is that this will make it harder to do stuff below the carb. now that i think of it, you may need longer screws for that bottom plate. i also posted a link for using the factory air cleaner on a weber, you could try that too.
rock_monkey is offline
post #4 of (permalink) Old 06-28-2002, 02:18 PM
here's another idea.....
take a stainless steel bowl with a flat bottom of sufficient size, trace and cut the carb opening in the bottom, mount under the filter. you may have to trim the bowl to get it to fit under the hood.
post #5 of (permalink) Old 06-28-2002, 02:46 PM
here's the stock intake cover and filter pic....
http://www.carbs.net/images/weber/K551-Si.jpg
