Nutter question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-27-2002, 03:24 PM
MaineJeep
Nutter question
What does the stock computer do to the ignition? I've heard it only retards timing if the knock sensor tells it to, but if that's true, then it seems like the Nutter bypass would do nothing.
Also, does anyone know the timing procedure and specs for an 87 YJ 258 with auto trans? I have no manual or under hood label, and I've heard 800 Rpm in gear and 1600 rpms with the vacume advance plugged, and unplugged, anyone know?
post #2 of (permalink) Old 06-27-2002, 03:40 PM
Re: Nutter question
This is deja vu all over again (you'll see what I mean), but I'll answer your question here, also. Timing should be 9 degrees (+/- 2) at 1600 RPM. That is with the vacuum advance disconnected and vacuum line plugged. Regarding the nutter bypass, I think you're right--the ability to retard your timing in certain situations (all of which I'm not sure of--they're encoded in the computer's little brain) is eliminated, but more than anything, it meant that I could remove all of those wires and hoses from the engine compartment, making maintenance MUCH easier. I've also increased my timing to 10-degrees at IDLE for a lot more "kick" without the worries of the computer trying to "correct" it (does require premium fuel, 89 octane is good for 8-degrees in my experience).
post #3 of (permalink) Old 06-28-2002, 09:08 AM
Official Historian
WILL's Avatar
Re: Nutter question
And why don't you have a manual?
WILL is offline
