Re: 1989 YJ Lift\'n and Winch\'n
One caution on the setup you are planning for the front end. The winch along with that heavy dual tube bumper may cause your front springs to sag, especially if you go with a softer setup. As an example, I am running a Pro Comp lift which most people find unbearably stiff, but my Warn winch on a channel mount along with a hi-lift jack on a custom mount evens out the stiff ride. If I was using a softer lift the Jeep would be tail high. So, think the whole setup out before you spring for the lift and accessories.
Brad (from the 4 Wheeling center of the universe, 4 corners USA)
