compression - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-29-2002, 08:43 PM
compression
what should the compression be on a 258 78 year jeep cj.
post #2 of (permalink) Old 05-29-2002, 10:23 PM
Re: compression
What it more important is the difference between cyls. I don't like to see more than about 5%.
post #3 of (permalink) Old 05-29-2002, 11:56 PM
Re: compression
Lets see,
The correct answer would be 150 psi.
If your engine is old and tired,
Look for about 120 dry and about 135 after you shoot a little engine oil or 3-in-1 oil in the cylinder.
This is acceptable, but you are getting close to needing a rebuild.
(There are a lot of 258's running around out there every day with less than 120 psi. It isn't recommended, but they still keep plugging along!)
NEVER USE WD-40 or Penetrating oil!
Those are solvents and will attack your bearing surfaces and cause scratching and galling of the cylinder walls and piston rings.
<hr>
You are looking for about 10% between cylinders at the rated compression.
That means 15 PSI between the highest and lowest gauge reading is within normal limits.
<hr>
You can tell a lot more if you first do a dry compression test of all cylinders, one at a time, with all the other spark plugs in.
Then do a wet compression test, the same way, one at a time.
Then do the test again, but remove the plugs from the cylinders on either side of the cylinder you are testing.
This will give you a good idea if the head gasket is leaking between cylinders.
<hr>
Don't forget to do your ignition a big favor and disconnect the coil connector before you start cranking the engine over or forget and leave the key on!
That is real hard on the coil and module!
Junk Yard Genius is offline
