hp #s for 351 and/or 302 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-27-2002, 09:14 PM
Anybody know how much horsepower and torque these motors had stock? If not where can I find out? Also, what is a good transmission/x-case to go with it? I was thinking maybe t-18 and np205. How much would an adapter cost for a ford tranny to a dana 18? Thanks
post #2 of (permalink) Old 05-28-2002, 08:08 PM
Re: hp #s for 351 and/or 302
for what year & windsor or clevo .1977 ford cleveland
351 4v 316ft/lbs(429nm)@2700rpm...217hp(162kw)@4500rpm
302 4v 267ft/lbs(363nm)@3000rpm...202hp(151kw)@4600rpm where as the NEW 302 has
Power kW 200
Torque Nm 420
post #3 of (permalink) Old 05-28-2002, 11:01 PM
It is a 70's 351. Is there are large difference in power between a windsor or a cleveland. When you say new 302, how new are you talking about?
post #4 of (permalink) Old 05-29-2002, 08:52 PM
new as in 2000+....ive seen specs on 302s for as little as 140hp but 290hp for a 302 boss....without work the windsors were down on power because of there small ports..just cant breath properly but they are much lighter so power to weight came into play...the 302 boss is basically a 302w with 351c heads .... the windsor also revs much higher than a clevo....hen i find more specs i'll pass them on
post #5 of (permalink) Old 05-29-2002, 09:56 PM
The 96 and up 5.0 HO all have about 225hp. But they are very easily built to whatever HP you can afford.
You can easily get 300HP/340ftlbs with well chosen bolt on components, a good choice of cams, and port matching the heads. I had mine Dyno'd in Vegas at about 275hp at the rear wheels, but that was when I was running the E303 Cam. I have since swapped in a B303 cam which gives up a little HP for more torque and stronger power band in the lower RPM range. My engine came out of an 89 Lincoln Mark VII has about 89K miles on it, and nothing more than bolt on mods, and port matched stock heads.
My engine is very strong, it can easily idle in 3rd gear at 400 rpm under heavy load, then excelerate to 3000 rpm in about a 1/2 second without side stepping the clutch. It is about as good a rock crawling engine, as you could ask for.
H8monday is offline
