CJ:Is the heater core always supposed to be Hot? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-27-2002, 07:19 AM Thread Starter
TOM85CJ7's Avatar
This may be a little elementary, but I don't remember. The new heater core in my Scrambler is really Hot. This is after the engine has reached operating temperature. The Temp gauge reads at less than halfway toward the Cold side. I have a 180 thermostat and new coolant. When I installed the new core there obviously wasn't any sort of valve, So I am sure coolant is cycling through it at around 180. Am I correct?
Thanks,
TOM85CJ7 is offline
post #2 of (permalink) Old 05-27-2002, 07:22 AM
Smokngun's Avatar
Re: CJ:Is the heater core always supposed to be Hot?
You are right, coolant flows through the heater core all the time. Some vehicles have a valve that controls the amount of flow through the heater core to regulate the interior temp, but CJ's use blend air doors in the heater box to regulate it.
Smokngun is offline
post #3 of (permalink) Old 05-27-2002, 09:10 AM
What about putting in a bypass? I was thinking of doing it to my TJ. Using 2 Ts, short piece of hose, and 2 valves. This way I could shut the heat off during the summer. Will the core get damaged with no circulation though?
AC97TJ is offline
post #4 of (permalink) Old 05-27-2002, 11:25 AM
You shouldn't need the bypass and two valves. Just put a shutoff in the supply line. I've heard of the core getting plugged with sediment in old beaters, but a well-maintained vehicle shouldn't have that problem.
Jim_Lou is offline
post #5 of (permalink) Old 05-27-2002, 11:40 AM Thread Starter
TOM85CJ7's Avatar
The supply would be the line from the top of the water pump. Correct??
Later,
TOM85CJ7 is offline
post #6 of (permalink) Old 05-27-2002, 12:01 PM
My YJ (258) won't flow into the heater core unless the heater thingi in the cab is set to heat. not cold.
Found out the hard way while filling the coolant. I had to open the valve to get it full otherwise it was way low when I started the engine and used the heater.
But I also have a manifold heater/cooler.. so I dunno what the story behind my Jeep is.
Infernozx is offline
post #7 of (permalink) Old 05-27-2002, 12:37 PM
Don't forget, coolant is also a lubricant AND contains rust inhibitors. You do the math... [img]images/icons/wink.gif[/img]
post #8 of (permalink) Old 05-27-2002, 03:02 PM
The supply hose generally is between the pump and the thermostat in the system. On most engines it's just below the thermostat.
I doubt it really makes any difference anyway. In either hose it will stop the flow.
Jim_Lou is offline
post #9 of (permalink) Old 05-27-2002, 04:24 PM
Yeah, the water is supposed to flow all the time. It uses a blend door to control temperature. If the blend door works right, there's no reason to shut off the water, but if you did stop it, you'd need a bypass, not just a shut off. Since you probably have a heated intake, a shut off would stop the flow to the intake manifold also.
dschwab9 is offline
post #10 of (permalink) Old 05-27-2002, 04:44 PM
Raduckal's Avatar
Some older ford trucks had an "H" shaped coolant bypass valve that would do just what you are talking about, mid to late 70's I think.
Raduckal is offline
