loose steering - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-26-2002, 09:01 PM Thread Starter
loose steering
My steering is real loose by loose I mean its real easy to turn, too easy, so easy its probably a little dangerous. Im running 35in supper swampers and without even moving I can spin the steering wheel like the wheel of fortune and the tires will move at a 45 degree angle. Anyone had this problem? My power steering box is leaking pretty good too, do you think the box may be wore out? Any Ideas?
rubiconvict is offline
post #2 of (permalink) Old 05-26-2002, 09:14 PM
Re: loose steering
Check the bolts on the steering box from the frame.
Snug them down
Check the bolt on top of the box, see if it is snug too..
When did this start?
Maybe with the large tires, you have ripped one of the bolts out?I think after you get real large tires, you need a steering gear brace.
Other than that, I don't know..
JoeyCJ55 is offline
post #3 of (permalink) Old 05-26-2002, 09:28 PM Thread Starter
Re: loose steering
I'll check that out thanks , its been like that for a while but it doesnt wonder on the road, it actually drives pretty good on the road, just reeeaaalllly easy to turn. I had one guy tell me the gears in the box were probably worn out but I wanted a second opinion from my fellow jeepers
post #4 of (permalink) Old 05-26-2002, 09:39 PM
Official Historian
WILL's Avatar
Re: loose steering
Don't touch the bolt on top of the steering gear until you read how to adjust it. If you get it too tight or loose, you'll ruin your steering gear. It has to be adjusted with the steering shaft and pitman arm disconnected.
WILL is offline
post #5 of (permalink) Old 05-26-2002, 10:46 PM
Re: loose steering
you can screw it up by tigthening it up too much?
well that sucks [img]images/icons/frown.gif[/img]
I wonder if mine will eventually give up now..
bad news [img]images/icons/frown.gif[/img]
JoeyCJ55 is offline
post #6 of (permalink) Old 05-26-2002, 11:22 PM
Re: loose steering
Maybe it's the loose nut behind the wheel?
I couldn't resist [img]images/icons/smile.gif[/img]
Jeeplvr is offline
post #7 of (permalink) Old 05-27-2002, 12:25 AM Thread Starter
Re: loose steering
yea mabey a little bit of that too
post #8 of (permalink) Old 05-27-2002, 12:32 PM
Re: loose steering
Is this a power steering box? If so, it could be a bad spring in the box. There's a valve that uses force applied to the steering wheel to control the hydraulic assist. A spring counteracts the valve. If the spring gets weak, I think, it can make the steering one-finger easy. I think it works that way - it's been a long time since I took one apart.
Anyway, it could be a problem in the steering box, which is something to take very seriously.
Jim_Lou is offline
