CJ - REbuilding 304, advance the timing? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-25-2002, 11:02 PM
im rebuilding my 304, and if im not mistaken, the timing is retarded 4 degrees from the factory. i am thinking about advancing it that 4 degrees when i dial in my cam. are there any bad things that could result from doing this? and how much power might i gain from this ? -- Andy
post #2 of (permalink) Old 05-26-2002, 09:24 AM
dave's Avatar
Re: CJ - REbuilding 304, advance the timing?
Ok, very good question. Quite often there is confusion between spark timing and valve train timing / camshaft timing. You seen to have a good idea that what your wanting to do is advance the valve train timing / camshaft timing. The short version explaination of advancing the valve train timing / camshaft timing will shift the torque and horsepower performance to a slightly lower RPM. For example if the 304 has the camshaft installed to factory specs, and for example the let's say the the max torque is 310 Ft. Lbs @ 3800 RPM's and max horsepower is 265 at 4200 RPM's. Then let's say for example the valve train timing / camshaft timing is adavanced by 4 degrees a typical shift in performance would have still have the max torque at 310 Ft. Lbs @ but lowered to 3500 RPM's and the max horsepower would still be 265 but lowered to 3900 RPM's. I'm not an expert with the AMC 304, I more a Chevy 350 expert. Quite often, I'll install a Chevy 350 camshaft plus 2 degrees for pickup engines that usually do towing or mild 4X4 off-road use.
dave
dave is offline
post #3 of (permalink) Old 05-26-2002, 01:57 PM
thanks dave, that was very helpful. so advancing the timing doesnt actually give you more power, just gives you the power when you need it, that makes sense. i was considering going with a 350/TH350 setup, but the adapter for the th350 to the dana 300 is 580 bucks! ouch. so im gonna stick with the 304 for now
