727 to 300 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-26-2002, 02:05 PM
727 to 300
Will all 727 trannies hook to a jeep 300 transfer case as long as the tranny is out of a four wheel drive? Also will the tranny bolt to a 304?
post #2 of (permalink) Old 04-26-2002, 02:22 PM
JesseA
Re: 727 to 300
The 727 Has to come from an AMC (258 304-401 it doesnt matter, the V-8s are all built around the same block and the sixes have the same bolt pattern). The bellhousing bolt pattern is different for the AMCs and Chryslers.
Sources say you need a 4 inch lift to clear the pan with the front driveshaft.
There is an article on the jeep web on the 727/Dana swap.
Jesse
post #3 of (permalink) Old 04-26-2002, 02:44 PM
Re: 727 to 300
THANKS, NEXT IS THE OUT PUT SHAFT ON THE TRANNY. DOES IT MATTER IF THE 300 WAS BOLTED TO A MANUAL TRANNY AND NOT A AUTO.
post #4 of (permalink) Old 04-26-2002, 04:05 PM
Re: 727 to 300
Hey there, I am about to do this also so I hope it does work. As for the input.. the 300's all have 23 spline, as far as I know.I am still waiting on the junkyard for the tranny , it has been very wet here so that has been slowing the process down due to a mess at the yard.But I am very excited.I have been told by many that the 727 is about the best auto to use in a short wheel base jeep.
good luck with your prodject!!
post #5 of (permalink) Old 04-26-2002, 08:28 PM
Re: 727 to 300
Ok, but does the 300 just bolt up to the 727 with no adapter? I can find Wagoneer 727's probably easy around here. I got my 300 just sitting around, if I can find a good auto to run it with then I'll build a comp. buggy with them! if they do bolt up I cann't see why you couldn't clock the 300 so that the driveshaft was out of the way.
post #6 of (permalink) Old 04-26-2002, 11:51 PM
Re: 727 to 300
Yep they sure will. Waggie 727s with a NP transfer case behind them will bolt right up to a Dana 300. I'm using a 727 from a '83 Wagoneer with a Dana 300 behind in in my CJ6.
post #7 of (permalink) Old 04-28-2002, 05:22 PM
SWEET!
did you clock your D300? what's the 1st gear ratio of the 727's? thanks
post #8 of (permalink) Old 04-28-2002, 08:09 PM
Leigh_Smith
Re: SWEET!
I believe the 1st gear is 2.45. Clocking the 300 will put the front drive shaft even closer to the part of the tranny that causes interference.
post #9 of (permalink) Old 04-29-2002, 08:25 AM
Re: 727 to 300
You will also have to change your rear end, off set pumpkin ya know.
