klunk cj7 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-27-1999, 03:35 PM
klunk cj7
I would appreciate any suggestions on what the klunk <technical term> is in the rear of my '85 CJ7. I have changed the u-joints and still have same klunk. It klunks one time when the engine is braking (jeep in gear and let up on accelerator). It seems louder near the rear left wheel from outside the jeep. Thanks
post #2 of (permalink) Old 09-27-1999, 04:52 PM
Re: klunk cj7
Might be a broken axle. My '83 CJ had the two piece axle (AMC 20 rear end) and when it broke it made a klunking sound
like you describe. I replaced mine with Mosser one piece axles.
post #3 of (permalink) Old 09-27-1999, 05:20 PM
Re: klunk cj7
The other reply was on the right track possibly. But, the axle probably isn't broken, the nut on the end is maybe loose or you have partially spun the 2 piece design, or both.
Brad (from the 4 Wheeling center of the universe, 4 corners USA)
post #4 of (permalink) Old 09-27-1999, 06:53 PM
Re: klunk cj7
Before you take everything apart,check if your u-bolts are tight.I had the klunk when I un-clutched to get the jeep moving and also when I down shifted hard.Hope this helps
Ben
winchboy is offline
post #5 of (permalink) Old 09-27-1999, 08:12 PM
Re: klunk cj7
sounds almost like the problem I had with my 86 cj , I installed the genuine gear one peice rear axles, and the problem was solved, unless you owned your jeep since new,I would suspect the previous owner/s might not have kept them torqued, even if this wouldn't solve your problem it is definitely a peice of mind modification.
post #6 of (permalink) Old 09-28-1999, 02:27 AM
Re: klunk cj7
Hitwoman, do yourself a favor before you do anything and get underneath and with the jeeps driveshaft grasp it and see if you have a lot of movement. I have an 82 and have been thru this twice already and I found that the "backlash on the ring and pinion wrong.You should have some play but not alot.
