How high is your jeep? - Page 2 - Off-Road Forums & Discussion Groups
post #11 of (permalink) Old 04-19-2002, 11:16 AM
RickB's Avatar
Re: How high is your jeep?
My frame measures 19-1/2" to the bottom on the drivers side and 19-3/4" on the passenger side. This measurement was taken on the frame about in the middle of the door.
RickB is offline
post #12 of (permalink) Old 04-19-2002, 12:41 PM
madmaxx
79 CJ-7 2.5" springs, soa, 3"body lift(soon to be gone), and about .5" in shackles. from ground to bottom of frame under the door is approx 27" , from ground to top of roll-bar is approx 89"(so after the body lift is gone ~ 86")
post #13 of (permalink) Old 04-19-2002, 04:25 PM
my yj's frame is about 25 1/2" off the ground, with a spring over using about 2" lift springs........and worn out 35" tires
3/4tonYJ is offline
post #14 of (permalink) Old 04-19-2002, 05:03 PM
From the ground up to the drivers side is 24.5. SOA, 2.5 procomp sprinf with BFG AT 35's. CJ7
WallyCJ7 is offline
post #15 of (permalink) Old 04-19-2002, 05:12 PM
I have a 97 TJ 4.0, AX-15, Rubicon Express 3.5 Super-flex system, Q78 Swamper TSL on rockcrawler 15X8 rims.
My TJ heights are as follows:
Driver side rocker to ground 26"
Passenger side rocker to ground 25 1/2"
skid plate at lowest point to ground 18"
front D30 lowest point to ground 12 3/4"
rear D44 lowest point to ground 11"
poly body mounts but no lift from them.
I don't have the stock specs. sorry[img]images/icons/frown.gif[/img]
AC97TJ is offline
post #16 of (permalink) Old 04-19-2002, 05:12 PM
sas87yj
ok i'll play [img]images/icons/smile.gif[/img]
yj
4.5 RE
1" body(doesn't raise the frame)
32" mtr's
19.5" to bottom frame
NOT HIGH ENOUGH!
TO BE REVISED [img]images/icons/smile.gif[/img]
post #17 of (permalink) Old 04-19-2002, 05:13 PM
27.5" on both sides to the bottom of the frame...89 YJ SOA and worn out CJ-7 lift springs
mobdawg is offline
post #18 of (permalink) Old 04-19-2002, 05:59 PM
jeeperjohn's Avatar
With a spring over, add a leaf, a 2" bodylift and 33" Swampers I am at 23" to the bottom of the frame and 29" to the rocker panel.
jeeperjohn is offline
post #19 of (permalink) Old 04-19-2002, 06:19 PM
Pooh-Bah
pbmcauliffe's Avatar
CJ7 SOA with 7 leaf hd CJ rear springs front and rear, MORE SRS that adds 1", 37" MT/R's @ 6lbs gets me 24" at frame, 30" to bottom of trimmed tub (no body lift) and 20" to bottom of custom x-member.
pbmcauliffe is offline
post #20 of (permalink) Old 04-19-2002, 07:10 PM
My rockers are a bit different so they sit higher than a standard set up.
H8monday is offline
