Re: SOA vs. SUA
There are 2 types of SOA suspensions, those that have a well designed anti wrap bar, and those that need a well designed wrap bar.
You can use longer spring perches,(I have, them on mine), you can use helper springs,(I have experimented with dozens of combos), you can try waving a magic chicken over your head in a clockwise circle while dancing the anti wrap chat on one foot,...but an SOA suspension needs an anti wrap bar,...PERIOD!!!
Once you install one, you will be amazed at how much better your traction is, and you will notice it even on the street as a drastic improvement.
Dont kid yourself that your suspension is working, just because you havent destroyed your springs in a catastrophic S wrap failure.
Its well worth the Saturday it takes to build one and the $75 in steel, bolts and bushings.
