TR upgrade question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-17-2002, 10:00 AM Thread Starter
TR upgrade question
My cat didn't run away or any thing but i do have a question. In the post "Which TFI coil and how many volts for TR upgrade?" there where a few diffrent wireing diagrams which on is right for a 85 4.2? I'm gathering parts / info and would like to try to get it done this weekend (wife permitting). How long does it take? And do I need to mess with the timeing?
Thanks
popazeus is offline
post #2 of (permalink) Old 04-17-2002, 10:08 AM
Re: TR upgrade question
The second drawing is the most accurate one in the post. The first is just plain wrong and the last one is for a ford. However, the first one is tailored to the 1978-79 model years. I am sure it is very similar but you should match the color of your wires to the diagram to make sure
The upgrade is easy to do. If you buy pre-made wires, the whole thing should take less than two hours. 75% of your time will be making a bracket for the new coil. It may be worth your time to go to a yard and buy one.
sevensandeights is offline
post #3 of (permalink) Old 04-17-2002, 11:49 AM Thread Starter
what do you mean pre-made wires? and what is E.E.C?
thanks
popazeus is offline
post #4 of (permalink) Old 04-17-2002, 02:53 PM
Pre-made spark plug wires, like for a '95 Jeep with a 4.0 liter engine is what you are going to need...
E.E.C. is Ford's way of saying the distributor no longer has vacuum advance, the computer is taking the timing chores over.
E.E.C. is Electronic Engine Control.
<hr>
You don't need a diagram for an '85, you aren't changing any wiring.
You need the following...
From '82 Ford F-150 pickup with 300 CID I-6
Distributor Cap Adaptor
Distributor Cap &amp; Rotor with BRASS TERMINALS
One set of premium spark plug wires from a '95 Jeep with 4.0 Liter engine.
If you decide to change the coil to the E-core...
The ignition coil from a '92 Ford Escort with I-4 Engine
A Coil connector from NAPA, P/N ICC-1
Crimp on spade terminals, and push them into the old coil connector.
(this way, if the new coil fails, you can use either type coil to get home)
Watch for Red wire to Red wire, Green wire to Green wire.
This is simply a tune up, no new wiring is involved.
Junk Yard Genius is offline
post #5 of (permalink) Old 04-17-2002, 05:48 PM Thread Starter
thanks ... any recomendations on how / where to put the new coil?
popazeus is offline
post #6 of (permalink) Old 04-17-2002, 10:35 PM
You REALLY don't want me to tell you where to put it! [img]images/icons/wink.gif[/img]
Anywhere is fine...
Most people choose the intake close to the distributor, or the top of the inner fender.
Either is find as long as you use a top quality (I suggest MSD 8.8) coil wire.
post #7 of (permalink) Old 04-18-2002, 09:06 AM Thread Starter
ha ha [img]images/icons/smile.gif[/img] I should have see that comming. I just asked because on the earlier post said 75% of the time was making the mount / mounting the coil
thanks
popazeus is offline
post #8 of (permalink) Old 04-18-2002, 01:14 PM
I did the upgrade to an AMC V8 and modified the factory bracket. I think the easiest and safest place for a 258 I6 would be on the fender. However, if you do this you will probably need a longer coil wire.
