OT - i have too much extra CB antenna coax - help - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-15-2002, 09:57 AM
Joker2002
I know that some of you Jeepers out there are CB people, so maybe you can help me out with this problem.
I ordered a kit (antenna, coax, mounting bracket) that came with 18 ft of coax cable. However, for my application I will be needing MUCH less than that (probably around 6 or 7 feet). Is it ok to cut and splice (solder) the coax, or should you just figure out a way to wrap all 18 ft of it around the inside of your cabin? I've heard that making a loop (spool) might be an easy way to deal with it, but that it is bad because it causes signal backup or something like that. What is the best way for me to deal with so much coax?
PS: In case it matters, I'm running the antenna on my hood, so the coax will be entering my cabin through the firewall.
post #2 of (permalink) Old 04-15-2002, 10:59 AM
Re: OT - i have too much extra CB antenna coax - help
The only way to splice it is by putting new connectors on it and using a coupler. Just cut it at the length you want and solder a new connector on. Radio Shack. Or if you're cheap like me you can unsolder the old connector and reuse it. Unless it's crimped on.
Jim_Lou is offline
post #3 of (permalink) Old 04-15-2002, 11:08 AM
RickB's Avatar
the search is working again, here's what I found:
<a target="_blank" href=http://tellico.off-road.com/ubbthreads/showflat.php?Cat=&amp;Board=offroadjeepshort&amp;N umber=701000&amp;page=&amp;view=&amp;sb=&amp;o=&am p;vc=1>http://tellico.off-road.com/ubbthreads/showflat.php?Cat=&amp;Board=offroadjeepshort&amp;N umber=701000&amp;page=&amp;view=&amp;sb=&amp;o=&am p;vc=1</a>
RickB is offline
post #4 of (permalink) Old 04-15-2002, 12:09 PM
The 18 feet is approximately 1/2 wavelength (not including the veolcity factor of the coax cable) What this means is it is easy to check the SWR at the back of the radio, rather than ideally at the antenna feed point (the mount).
What this means to you is get you SWR set, then cut the coax to length, and solder/crimp on another end.
If you plan on leaving the extra length DO NOT coil it up. This creates a field and will introduce noise. Run it in a random configuration.
