-   -   Nuttered Carb Questions (https://forums.off-road.com/jeep-short-wheelbase/115751-nuttered-carb-questions.html)
87Warrior 04-13-2002 01:15 AM
Last weekend we nuttered the YJ, replaced the valve cover gasket, and replaced the fuel pump. Riped all of the vaccum lines and such out of it. IT no longer blows smoke at stat up, STARTS and SHUTS off. The 258 now has a longer but steady power band.
I believe it is running rich. After the nutter it will drop from 60mph to 55mph going up a hill, and before with the computer it would stay at 60-petal to the metal- How could i check this? Will i possibly need to change the main jets, if so where do i get them from? I have not adjusted the air/idle mixture screw, will that help much at all?
Infernozx 04-13-2002 02:40 AM
Re: Nuttered Carb Questions
There was a discussion on this a while ago..
Someone mentioned that the nutter wasn't infact a good mod, because it basically made you run rich at idle..
87Warrior 04-13-2002 11:53 PM
IT is fine at idle. Just when going on the highway it does worse than the jeep stock. At highway speeds i try to keep the RPM up around 2-2.5. If it is running rich at idle, it is an idle air mixture problem. I will check this out tomorrow.
Infernozx 04-14-2002 12:52 AM
ok, so you have it running perfect at idle, instead of being rich.. I would bet its running lean when accereated then..
right?
87Warrior 04-14-2002 06:00 PM
That is true. So far i have not had time today to play with the mixture screws. When ttrying to travel up these long hills it feels like it is running rich though. Maybe somebody should stick their head down by the tail pipe and sniff at 60mph!
