Re: Ways of removing a wheel lock nut without the key
[img]images/icons/mad.gif[/img] All RIGHT, ALRIGHT, ALLRIGHT!!!!![img]images/icons/mad.gif[/img]What's WRONG with you guys!!!!????? If you were out in the boonies and away from tire shops, you wouldn't have those options, so let us SPEAK NO MORE of using the telephone or the credit card to solve this minor problem. He HAS the key.....it's just that he let Bozo use it without first admonishing BOZO about wrecking it. So here is what I did when I came upon a hapless motorist with this very same problem.[img]images/icons/tongue.gif[/img] Now......pay attention......get that Kat off the keyboard......put down that coffee cup.[img]images/icons/frown.gif[/img] The guy I came upon had a 3/4T Suburban with leaf springs in the rear and had a rear flat with the stripped lock nut keeping him from changing it.[img]images/icons/frown.gif[/img] I threw a chain around the front half of the rear spring and hooked the chain in a loop. I stuck a long 2 X 4 through the chain loop. He put the key in the socket of my big four-way lug wrench and put it on the lock nut. I used the 2 X 4 as a second-class lever to put enourmous END-O pressure on the outer end of that four-way such that the worn out key COULD NOT POP OUT and slip.[img]images/icons/tongue.gif[/img] He had only to rotate the big four-way and unscrew the lock nut. END of problem.[img]images/icons/smile.gif[/img] He drove it home with only seven lugs, but no big deal.[img]images/icons/tongue.gif[/img] There.....see how easy that was![img]images/icons/frown.gif[/img] Now go and sin no more![img]images/icons/crazy.gif[/img]
