PVC / Breather reversed? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-11-2002, 01:48 PM
What would happen if you ran the PVC in the rear hole on the valve cover (258) and the breather in the front. Just realized mine was set up backwards and I burn alot of oil in a new motor. I'll be switching it later this week, just curious to see if there is a reason for where they are placed.
post #2 of (permalink) Old 04-11-2002, 02:18 PM
Official Historian
WILL's Avatar
Re: PVC / Breather reversed?
Ventilation wise, probably nothing. But, there might be a baffle on one and not the other.
WILL is offline
post #3 of (permalink) Old 04-11-2002, 02:46 PM
It should work fine as long as there is a baffle on both holes. Mine has two baffles, but I'm not sure if they all do.
dschwab9 is offline
post #4 of (permalink) Old 04-11-2002, 03:58 PM
Mine was setup like that too when I bought it. I think the previous owner had done it that way since my engine has so much blowby and the longer hose from the front port to the air cleaner reduced the amount of oil that made it into the air cleaner. Also, if you do have blowby, take both the PCV and the breather hose out of their holes in the cover and, with the engine running, see if more exhaust comes out of one vs the other. On mine, there seemed to more coming out of the rear port.
texas1al is offline
post #5 of (permalink) Old 04-11-2002, 05:00 PM
Official Historian
WILL's Avatar
Maybe it just seemed like more was coming from the rear because it is farther from the fan. If you are going to try that, disable the fan.
WILL is offline
post #6 of (permalink) Old 04-11-2002, 05:26 PM
WILL,
Good point, I was a little confused why there seemed to be more coming from the back. Anyway, now I've got it setup right with the PCV up front and an oil recovery bottle in the breather line.
texas1al is offline
post #7 of (permalink) Old 04-11-2002, 08:05 PM
Glad I asked. This is starting to make sense now. When I replaced the valve cover gasket I noticed that this cover had some metal cut out of the inside of it (read NO baffles). This is a brand new rebuild, and I burn ALOT of oil. I don't think it's going by my new rings, but could it be that the PVC is pulling oil from the top of the engine, and burning it with the gas? BTW this engine smokes a good bit, but is by no means a smoke generator. Does this make sense?
Jon
post #8 of (permalink) Old 04-11-2002, 08:34 PM
Without baffles I think your PCV is probably pulling some oil. After all, the rockers throw around a lot of oil and the suction on the PCV is probably enough to draw it up into the manifold.
May want to design your own baffles, my replacement cover's just got some flat 4x2" metal pieces bolted on about 1/2" below the ports. They are boxed on the sides to keep oil from coming over and open on the long ends. They seem to keep most of the splash from getting to the ports, but also allow some oil to pool up there (not a significant amount).
texas1al is offline
