-   -   D20 dissasemble ? (https://forums.off-road.com/jeep-short-wheelbase/115459-d20-dissasemble.html)
**DONOTDELETE** 04-11-2002 06:55 AM
D20 dissasemble ?
I'm in the process of replacing the seals and gaskets on my D20. everything came apart fine with the exception of the 'front seal cover'. How do I get the cover to come off of the 2 rails? It only comes about 1/2 way and then stops. BTW, I'm only doing the seal/gaskets, so I would like to avoid pulling the gears out if possible. Any info is appreciated, thanks
Brhino 04-11-2002 09:14 AM
Re: D20 dissasemble ?
Is it the front seal on the output shaft or the front seal of the case. The front seal of the case I have always taken down completely to replace. You must remove gears and everything for this one I believe. It is hard to get it off. Usually stuck pretty good and it is the whole part. Try this for reference:
http://www.novak-adapt.com/knowledge...se_article.htm
**DONOTDELETE** 04-11-2002 01:24 PM
It is the gasket that goes between the main housing and the front output housing.
