would engine vacuum be powerfull enough for ARB ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-10-2002, 11:23 AM Thread Starter
elusive's Avatar
I have an arb for the wifes tj..I'd put it in for an upcomming run, but I really dont have the time/$$$ to get OBA in her jeep right now. Could I run some air line in and use a switch from a quadratrac jeep tapped off the power brake booster to run the arb?
elusive is offline
post #2 of (permalink) Old 04-10-2002, 11:55 AM
Re: would engine vacuum be powerfull enough for ARB ?
That's pretty far fetched, Chris ... [img]images/icons/tongue.gif[/img]
I have heard that in a pinch you can use a small electric tire inflator pump though. I guess it would be easy to set up a regulator on one so you didn't blow the ARBs seals.
Jaffer is offline
post #3 of (permalink) Old 04-10-2002, 11:57 AM
Official Historian
WILL's Avatar
I would think that running a vacuum line off the power booster will do a great job of providing enough vacuum to keep the locker disengaged.
WILL is offline
post #4 of (permalink) Old 04-10-2002, 12:24 PM
Caver Dave's Avatar
I was under the impression that ARBs took positive air pressure, not negative air pressure (vaccuum). If vaccuum can be used, just grab a vaccuum pump from a late model Ford PS. I think they're $75-100 new.
Caver Dave is offline
post #5 of (permalink) Old 04-10-2002, 01:31 PM
JeepnGreg's Avatar
yea i agree with Caver Dave....ARB take positive i believ....cuz you can fill your tires with their pump....so if they had a vacuum pump you'd be drainign your tires....
im sure theres other options besides the ARB brand pump...
JeepnGreg is offline
post #6 of (permalink) Old 04-10-2002, 01:33 PM
Official Historian
WILL's Avatar
Notice I said disengaged not engaged.
WILL is offline
post #7 of (permalink) Old 04-10-2002, 02:24 PM
I've never had my sandwich hooks on an ARB, but I'd think that it wouldn't be too tough to replace the air line with a flex cable, would it? It would be a reasonable fix until you can get around to OBA.
Jim_Lou is offline
post #8 of (permalink) Old 04-10-2002, 03:14 PM
I guess I don't get it either. The ARB is a "spring open" and "air shut" locker.
How would vacuum fit into the picture?
Jeeplvr is offline
post #9 of (permalink) Old 04-10-2002, 03:25 PM
GreenMachine's Avatar
I wonder if a smog pump off like a rx7 could be used for air.....hmmmm....
GreenMachine is offline
post #10 of (permalink) Old 04-10-2002, 04:51 PM
You need at least 60 pounds of pressure to engage an ARB, not vacuum. This pretty much eliminates an air pump which might put out 5-10 psi depending on back pressure.
