how will a 360 engine swap effect my performance? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-09-2002, 08:03 PM Thread Starter
I am planning a 360 swap into my jeep. I just added 33s and am thinking that I should re gear the jeep. I am wondering if the 360 will add enough power over the old tired 258 to turn those tires? I am currently running 3.54s but was thinking of upgrading to a lower ratio. I cant afford to do both the gear swap and the engine swap at the same time, as I am a college student on a limited budget, so will the 360 help my to high gear problem. I am sure eventually I will upgrade my gears, but cant do both now and a V8 seems to be more appeling to me at the time. Will the 360 get me by, will it help with my low gearing prob? I have a T18 so I can use the granny which spinns the tires fine.
WHat do you think
Tony
tonyscj5 is offline
post #2 of (permalink) Old 04-09-2002, 08:28 PM
Leigh_Smith
Re: how will a 360 engine swap effect my performance?
I wouldn't worry about it too much. Your jeep will drive fine but it all depends on what you expect from your jeep. Do the re-gear when funds allow and you will be used to the 360 by then and know how low you want to go.
post #3 of (permalink) Old 04-09-2002, 08:32 PM Thread Starter
Sounds good to me. Thats what I was thinking.
Does anyone know what the lowest ratio that was avilable for the dana 30 and amc20 stock. I was thinking I might be able to find a used set of gears? Probably not, but might be an option if they ever came around 4.10 or slightly higher or lower. Just a thought.
thanks for the reply.
Tony
tonyscj5 is offline
post #4 of (permalink) Old 04-10-2002, 10:13 AM
According to www.drivetraindirect.com....you can get down to 4.88s for both the AMC 20 and the D30....but I'd be wary....especially if you're syill using 2 piece shafts in the AMC 20.
-remy
post #5 of (permalink) Old 04-10-2002, 01:06 PM Thread Starter
Yeah...but did any applications come stock with these low gears. Has any one had any luck with swapped in used gears? Where is a good source of these used gears?
thanks
Tony
tonyscj5 is offline
post #6 of (permalink) Old 04-10-2002, 01:19 PM
Official Historian
WILL's Avatar
Without overdrive, I think you'll be happy with 3.54's with the 360 and 33's. I had that for a while (with an auto) an it was fine for the street. Due to the high first gear of the auto, I went to 4.10's and now at 70 the engine screams at 3000 rpm.
WILL is offline
post #7 of (permalink) Old 04-10-2002, 06:19 PM Thread Starter
What kind of RPMs will I be running at 65mph with 33s and 3.54s with the t18 tranny???
Thanks
Tony
tonyscj5 is offline
post #8 of (permalink) Old 04-10-2002, 07:10 PM
This is my favorite calculator
<a target="_blank" href=http://www.jeeptech.com/javaAps/gta.html>http://www.jeeptech.com/javaAps/gta.html</a>
BigHG is offline
