need a new coil any recomendations? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-09-2002, 09:33 AM Thread Starter
I need a new coil for my CJ7 (85 4.2) any recomendations?
Thanks
popazeus is offline
post #2 of (permalink) Old 04-09-2002, 09:38 AM
Mike86CJ7's Avatar
Re: need a new coil any recomendations?
Have you done the TR upgrade yet? If so, a stock type TFI coil should be sufficient, but the MSD Blaster coils have a little extra kick to them. If you haven't TR'd, then the cannister type MSD Blaster 2 is also a nice upgrade.
Mike86CJ7 is offline
post #3 of (permalink) Old 04-09-2002, 09:41 AM Thread Starter
whats the tr upgrade?
popazeus is offline
post #4 of (permalink) Old 04-09-2002, 09:49 AM
Mike86CJ7's Avatar
TeamRush upgrade. It replaces the stock, small distrubutor cap with a larger cap and replaces the cannister type coil with an electronic coil. Look here for details : <a target="_blank" href=http://www.swbbbs.freeservers.com/teamrush.htm>http://www.swbbbs.freeservers.com/teamrush.htm</a>
post #5 of (permalink) Old 04-09-2002, 06:07 PM
Drury's Avatar
If you get the hotter coil you must do the rest of the upgrade or the spark can jump the terminals in the cap and rotor. Also make sure to get the right wires. Otherwise, your wasting money. It is well worth it. You'll feel the difference.
Drury is offline
post #6 of (permalink) Old 04-10-2002, 03:12 PM
Cap adaptor, cap &amp; Rotor are under $30 for the premium ones with BRASS TERMINALS, no reason not to upgrade.
All from a '82 Ford F-150 Pickup, will bolt right on your distributor and work like stock components.
You will have to change spark plug wires.
Try from a '93 4.0 Liter Jeep. Most people report they fit really nicely.
If you want to, you can go to NAPA, get a ignition coil connector.
NAPA P/N ICC-1 (about $13)
And then trade the factory canister coil for the late model E-core coil.
Order the coil for a '92 Ford Escort. (between $15 &amp; $50 depending on quality at the discount auto parts stores)
<hr>
What this upgrade will do for you....
Cap Adaptor, Cap &amp; Rotor
Cap adaptor will raise the rotor up and away from the distributor housing, and cut down on the number if firings to ground. When your cap and rotor nose get a little carbon on them, the spark energy is just as happy to find ground inside the distributor housing rather than going to the spark plugs.
The larger Diameter cap, along with a much better internal design of the cap, will keep cross fires (spark energy going to the wrong terminal) and multiple fires (spark energy going to two or more terminals) to a minimum.
You also get the added benefit of the new HEI style plug wire terminals that leak less spark energy out, and keep moisture, dirt, grime and corrosion out better.
The taller and longer rotor will keep the spark energy up and away from the distributor internals, and it will get the spark to the correct terminal, with more room in between terminals with the larger cap, the spark will be more likely to go where you are trying to direct it.
Remember to use BRASS terminals only, otherwise you are wasting time.
(Aluminum terminals in the economy caps are for sh*t)
PLUG WIRES.
You are using plug wires that were designed to keep radio noise down in WW II aircraft.
By upgrading to the newer style plug wires, you are gaining several benefits.
Better noise suppression, more spark energy transfer to the plug, less spark energy loss through the wire and it's insulation, and much better connector ends.
The older 'Socket' type spark plug terminals are crap, and they will cost you performance.
IGNITION COIL.
By replacing the older oil filled canister coil, and going to the new style E-core coil, you will increase the three important components of ignition spark energy.
Duration. How long the spark lasts in the cylinder. The longer the spark lasts, the better chance you have of getting that cylinder to ignite and make power.
Voltage. You will need enough voltage to light the cylinder even under adverse conditions.
Amperage. You will need enough 'Electrical Volume' to keep the spark energy sustained to get every cylinder to fire every time.
By switching to the E-core coil, you will increase all three necessary components, and there are no draw backs.
The entire upgrade will...
Work with your current factory module, will decrease your emissions, increase your horse power, torque, fuel milage, top speed, midrange power, your idle quality will improve and make your morning starts faster and easier.
It's also just tune up parts that anyone can install...
Cap adaptor, Cap, Rotor, Plug Wires, Change the coil, have a beer....
Junk Yard Genius is offline
post #7 of (permalink) Old 04-10-2002, 03:39 PM Thread Starter
do you need to mess with the timing? I think I'm gona try this this weekend [img]images/icons/smile.gif[/img]
Thanks
popazeus is offline
post #8 of (permalink) Old 04-10-2002, 04:58 PM
<blockquote><font class="small">In reply to:</font><hr>
<hr></blockquote>
Aaron, what's the difference between that coil and the 80's TFI coil?
I think I used one for a mid 80's ford pickup on mine.
dschwab9 is offline
post #9 of (permalink) Old 04-10-2002, 05:13 PM
Official Historian
WILL's Avatar
Same coil, just less confusing for the counter "help" to look it up. There is only one choice with the escort.
WILL is offline
