SOA kit - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-26-2002, 09:02 AM Thread Starter
86CJ7's Avatar
SOA kit
I am ordering JCWhitney 7 leaf rear CJ springs for my CJ7. I was told to get a Rubicon Express SOA kit. Is this the best way to do a SOA or can I purchase perches and what ever else I will need seperatly? What exactly will I need for mounting the springs?
86CJ7 is offline
post #2 of (permalink) Old 03-26-2002, 09:20 AM
Re: SOA kit
The Rubicon Express kit doesn't address 2 very important issues with an SOA, the steering problems and rear wheel hop. SOA not as easy as it may at first appear.
post #3 of (permalink) Old 03-26-2002, 09:20 AM
Re: SOA kit
The soa kit from rubicon express is for yj's (i'm pretty sure) and doesn't include a lot, i think it includes spring perches (probably won't fit cj axles), drop pitman arm (ok steering solution, though i hi-steer set up is better), stainless brake lines (longer ones can be had from napa), Sway bar discos (their discos are crap and you may or may not run a sway bar), and maybe some other minor stuff like degree shims. The kit doesn't adress drive shafts or steering very well so i would just peice the stuff together.
Barrelroll
Jeeper99xj is offline
post #4 of (permalink) Old 03-26-2002, 11:28 AM
Pooh-Bah
pbmcauliffe's Avatar
Re: SOA kit
I did both my SOA's by just buying the parts I wanted/needed. You can get everything separetly, axle perches, brakelines, new front spring hangers (your springs are 2" wide, CJ rears are 2.5"), traction bar, steering, longer shocks, taller mounts, longer drivelines, angle finder, lots of grinding discs, and some other misc. stuff.
pbmcauliffe is offline
post #5 of (permalink) Old 03-26-2002, 11:47 AM Thread Starter
86CJ7's Avatar
Re: SOA kit
I have all the other stuff like high steering, brake lines, stuff like that. All I need is the stuff to mount the springs to the axles. Do I need new spring hangers, perches, etc?
86CJ7 is offline
post #6 of (permalink) Old 03-26-2002, 12:29 PM
Pooh-Bah
Re: SOA kit
You could cut the old perches off the axle, clean them up and re-use them, personally I buy new ones and save the hassle, under $20.00 for a set. If you use the CJ rear springs in the front, you will either have to change the spring mount to fit the wider 2.5" spring, or find a way to get the extra .5" of room. You should also change the shackle hanger for one designed for 2.5" wide springs. The rears are a direct swap. When I did it, I was using a SRS kit from M.O.R.E. so I ordered one for a YJ since they use the 2.5" wide springs.
post #7 of (permalink) Old 03-26-2002, 12:33 PM
jamgood96's Avatar
Re: SOA kit
Warrior products has a real nice kit. Comes with u-bolt plates, spring perches, shock mounts, and a few other things. I wish they had it when I did my SOA, since I ended up buying most my parts through them. A bundle pack would of been cheaper for me.
jamgood96 is offline
post #8 of (permalink) Old 03-26-2002, 12:51 PM
Hooch's Avatar
Re: SOA kit
Does anybody have any experience with the Full Traction bolt on SOA kit? I know it is a relatively new kit, but just wondered if any of you had heard anything. Seems an easy option, but not too sure about a bolt on system.
<a target="_blank" href=http://www.full-traction.com/boltonspoa.htm>http://www.full-traction.com/boltonspoa.htm</a>
Hooch is offline
post #9 of (permalink) Old 03-26-2002, 01:10 PM
Pooh-Bah
Re: SOA kit
Looks very expensive for what it is, also it doesn't deal with any of the big issues of a SOA (shocks, steering, axle wrap, brakelines, etc).
post #10 of (permalink) Old 03-26-2002, 01:16 PM
jamgood96's Avatar
Re: SOA kit
I agree. For the stuff you get, and the problems still left unsolved, it seems a bit expensive. It shouldn't be that much to piece together a kit like that from a local parts house. I know I got my shock perches for $20. And you could probably make the u-bolt plates yourself.
