-   -   Reamer (https://forums.off-road.com/jeep-short-wheelbase/109823-reamer.html)
**DONOTDELETE** 03-02-2002 05:52 AM
Reamer
Hey
I need to know what is the proper name of the tool that ream's the hole's for the GM, tie rod ends for a 1/2 ton pick-up & what size it is.
Thanks
Jim_Lou 03-02-2002 06:15 AM
Re: Reamer
I went through that search a few weeks ago, and here's what I did. My parts house had the specs on the stud for the tie rod end I was using. It was just over 0.50" on the small end, and tapered at the rate of 1.5" per foot. I couldn't find the right reamer at any of my machine tool suppliers, so I had a tool sharpener modify a used end mill to the right size and taper. It cost $45, including the used end mill. It did a perfect job.
The tool has a 3/4" shank, though, so it has to be used in a milling machine or a very large drill press. I don't think it could be used very well as a hand reamer because of the agressive cutting geometry. A tool sharpener could grind the shank down, though.
Since then I have heard, but not verified, that Snap On has a tapered reamer for the purpose. I suspect that the 1.5" per foot taper is pretty much standard for tie rod ends and ball joint studs, with the difference being in the size of the hole.
I hope this helps.
Jim
I might have been born at night, but it wasn't LAST night.
Jeeplvr 03-02-2002 11:16 AM
Re: Reamer
When you click this link, look at the bottom of the page. This is the reamer I bought. It works great and very good quality. You only need a 1/2" drill.
Click for stock car products reamer
http://www.trailhed.com/images/trailhed.jpgTrailhed.com
ozarkjeep 03-02-2002 01:21 PM
Re: Reamer
search the onlione stock car ( race car shops) shops, they sell them as 1 1 /2 inch per foot tapered reamer, GM large size I think they call it.
usually $79 or so.
OzarkJeep
too small to be seen, and too big to control, and treated like a walking bomb...
