Engine Knocking when I engage Clutch ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-01-2002, 08:12 PM Thread Starter
I have a disturbing Knocking that seems to apear when I press the clutch and goes away when I release it. It sounds like it comes from the firewall area, not the floorboard.
The knocking sounds like an engine knocking, but it only happens with the clutch pushed in.
Both the transmission (T-150) and engine (258) are running better than ever before. I was just wondering how do diagnose the "Knock".
I've got too much month at the end of my money!
1977CJ7 is offline
post #2 of (permalink) Old 03-01-2002, 08:42 PM
sas87yj
Re: Engine Knocking when I engage Clutch ?
well, it seems it would be a clutch component like the throwout bearing or pilot bushing/bearing.
post #3 of (permalink) Old 03-01-2002, 09:16 PM
Official Historian
WILL's Avatar
Do you have a worn out bushing in your clutch linkage thats getting rattled by the engine?
WILL is offline
post #4 of (permalink) Old 03-01-2002, 11:37 PM
One possibility is the thrust bearing in the engine is worn. This would allow the clutch to push the crank forward causing just such a knock.
Member and co-founder of the Christian Off-Road Association.
1982 Suburban
1948 CJ2A
ChristianOffroad is offline
post #5 of (permalink) Old 03-02-2002, 09:25 PM
Sounds like the throw out bearing if it starts when you touch the peddle and the bearing makes contact with the pressure plate then stops when you release. Time to pull the tranny!
Good Luck!
Kriss
post #6 of (permalink) Old 03-03-2002, 02:28 PM Thread Starter
I just had the transmission out a few weeks ago replacing seals, the throwout bearing looked OK? but I know looks are decieving, I will probably wait till it gets bad then pull it and do a new clutch to boot.
thanks for the input
1977CJ7 is offline
post #7 of (permalink) Old 03-03-2002, 09:32 PM
As a rule, EVERYTIME I pull a tranny it gets a new throw out bearing and pilot bushing as it is just to much work to repull the tranny to put in a new one later.
Good Luck!
Kriss
