Need info on where ignition wires go(pic included) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-28-2002, 05:53 PM Thread Starter
Could anyone please tell me what each wire does/ where they go.
This is coming out of the back of my chevy 4.3L v6's distributor.I believe it is an 86 engine from a c10 or a similar pickup.
Two are connected to each other while the other two aren't connected to anything.
Any help is appreciated!
78 CJ7
Spring over 33's
4.3L V6, TH350
JoeyCJ55 is offline
post #2 of (permalink) Old 02-28-2002, 06:23 PM
Re: Need info on where ignition wires go(pic included)
there is no picture
So little time, So many trails.
post #3 of (permalink) Old 02-28-2002, 06:38 PM Thread Starter
haha sorry
78 CJ7
Spring over 33's
4.3L V6, TH350
JoeyCJ55 is offline
post #4 of (permalink) Old 02-28-2002, 06:46 PM
Its been a while since I have messed with a gm motor but that is the distributor with the coil in the cap right. If so I think those wires should have a plug on them and circle back up to the cap and coil. Then you should have a wired supplied by the accessory going to the cap also. Not realy for sure until I take a look at one. Ill see what I can figure out but Im sure someone else here should know...
post #5 of (permalink) Old 02-28-2002, 06:59 PM Thread Starter
there is a plug on the other side which does do that.
one is positive,and the other two go to the top of the coil
78 CJ7
Spring over 33's
4.3L V6, TH350
JoeyCJ55 is offline
post #6 of (permalink) Old 03-01-2002, 08:12 AM
Is it running right now or are you having problems with it. Im not sure on what those wires are for. It might be something like they are doing on later model distributors. Is that or was it a fuel injected motor. If so I have heard that you have to splice some wires coming out of the module in the distributor to return the current through the module. I have never done it before or seen it done or even what year model distributors they started doing this to, but I have heard of guys doing this for better performance parts that are stock. I guess this allows you to use it without a computer if you are running a carb instead of EFI. I'll ask around and see, but I bet thats whats going on there. I believe it was a guy I work with that told me about this when I told him I put a 350 in my commando and hardly have room for the distributor. Chevy eventualy changed that distributor and went with one that has an external coil that allows more room for firewall clearance.
post #7 of (permalink) Old 03-01-2002, 03:19 PM Thread Starter
its running right now, but not real well.
I bet thats exactly what it was,it was probably a fuel injected engine.
I'll go ahead and make a better connection on that wire.
78 CJ7
Spring over 33's
4.3L V6, TH350
JoeyCJ55 is offline
