cheap rocker panel options - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-28-2002, 03:23 PM
any ideas/pics
when i say cheap, i mean next to nothin'
i'm broke, but i need 'em
post #2 of (permalink) Old 02-28-2002, 03:34 PM
Re: cheap rocker panel options
Not sure what you are after, but: Sheet metal pop rivoted looks clean for repairing rusty panels. Angle iron bolted to the bottom edge makes for a nice edge and is cheap and strong. No welding required. Hacksaw, aircraft snips and pop rivot tools.
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
post #3 of (permalink) Old 02-28-2002, 04:48 PM
If you do the angle iron thing you should either put Herculiner on the body first or seal up around the angle iron with silicone to prevent moisture from getting behind the angle iron and rusting the area.Also some of the guys here put POR paint on first because in stops rust.
Take care of the pennies and the dollars will take care of themselves.
post #4 of (permalink) Old 02-28-2002, 05:49 PM
Angle iron is probably the cheapest, and works the best..
http://pub59.ezboard.com/fnewengland...icID=397.topic
Bob in Ma.
Bob Ackley is offline
post #5 of (permalink) Old 02-28-2002, 08:30 PM
I second the angle iron.
Bob, are the holes in your rocker guards countersunk?
I'm currently using round head allen bolts, but I got the wrong kind and they are rusting. I like the idea of having them stick out as little as possible.
Thanks,
Dan 84 CJ-7,Weber,HEI. 95 ZJ,V8. http://www.cableone.net/wdohrn
Dan 84 CJ-7 is offline
post #6 of (permalink) Old 02-28-2002, 08:47 PM
Just paint the bolts, I'm using button head allens, I just painted them.
Brad
ORC Land Use Editor
and
http://home.off-road.com/~rockgarden
post #7 of (permalink) Old 02-28-2002, 09:00 PM
I made some out of 3x3x1/4 angle iron and welded three mounts on them out of the same material and bolted them to the body mount outriggers. They are extremely strong and cost about $22. I have some bad pics of them, if you want I can scan them in.
"UPANOVR"
glasscj is offline
post #8 of (permalink) Old 02-28-2002, 09:49 PM
Leigh_Smith
Although I haven't made them yet, I was going to use square tubing (2 x 4) sticking out from the body so it would act as a step. It would have to be tied to the frame or put angle on top and bolt that on.
I have diamondplate sides and angle iron would leave lots of voids to catch mud, which is the last thing i need.
It will never be finished unless it burns up in the woods.
post #9 of (permalink) Old 03-01-2002, 05:21 PM
Yes, I countersunk the heads of my fasteners. I used some black allenhead bolts that were readily available in most hardware stores.
I prefer the smooth look!!
Bob in Ma.
