Official Historian
Re: Driveline combo
Probably the easiest way would be to get a th400 that was used between the amc 360 and the quadratrac. Then, just swap the output shaft for the one that fits the transfer case you want to use. btw, That combination doesn't sound right. I don't think the TH400 was ever used with the dana 300, just the dana 20. If that dana 300 is behind a th400, it is probably an aftermarket adapter.
