My Jeep makes "Bird-like" sounds when at high RPMs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-28-2002, 11:27 AM Thread Starter
My Jeep makes \"Bird-like\" sounds when at high RPMs
It only happens when I put a good load on the engine, say when going up a steep freeway hill at 70mph, The noise sounds like a bunch of chirping parakeets or something...[img]/wwwthreads_images/icons/smile.gif[/img]
It goes away after about 30 minutes. And It is GONE out of town gone. Then when I turn off the car, let it sit for about a day, the noise comes back? at first I was suspecting the front driveshaft maybe was spinning fast enough to vibrate due to the angle, and actually touching the header pipe(only about 1/4 inch away). possible?
Who knows..
Its an 87 wrangler with a 258 and an auto tranny..
Thanks.
...One New Car, A Few New Parts, A Lot More Scars...
94 ZJ
89 FSJ - 6-inch Rustys kit, XTerrains 33"S
87 YJ - 5" of lift, 33BFG"s. ARB snorkel. Borla Header.
48 CJ2A
YJAroundTheWorld is offline
post #2 of (permalink) Old 02-28-2002, 11:38 AM
Re: My Jeep makes \"Bird-like\" sounds when at high RPMs
Car......??? Um, tell me that was a slip-up, [img]/wwwthreads_images/icons/smile.gif[/img]
post #3 of (permalink) Old 02-28-2002, 11:46 AM
After driving, check the u joints by hand to see if any are hot. Mine made chirping noises as I pulled away from a stop when the needles went bad on one cap. That cap was noticable warmer than the rest when I touched them by hand. Heat = friction (or is it the other way around?)
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
post #4 of (permalink) Old 03-01-2002, 12:20 PM
Im going way out on a limb here. But my throw-out bearing in my TJ is chattering a lot. At first it only did it in the morning (after sitting).
84CJ7 SOA,35's,OnboardAir,Dual winches,Full Cage,Snorkels, and more
OverMost 4WD Club
post #5 of (permalink) Old 03-01-2002, 04:26 PM
sas87yj
i'd like to know what you been smokin, cause i want some too
chirpin like birds? ha ha ha
it's not pinging is it- detonation? you know that sound right? when you put a load on the engine as you said, it would ping then. BUT it wouuldn't go away unless it was bad gas and you put some good in or you retarded the timing.
hmmm, let me head on down to the pet store and listen to a few parakeets was it?
post #6 of (permalink) Old 03-01-2002, 05:45 PM
if it is making the chirping parakeet noise I'd check for a U-joint just starting to go....<font color=red>BUT</font color=red>....If it starts making the caw caw caw crow noise you are screwed[img]/wwwthreads_images/icons/crazy.gif[/img][img]/wwwthreads_images/icons/crazy.gif[/img][img]/wwwthreads_images/icons/crazy.gif[/img][img]/wwwthreads_images/icons/crazy.gif[/img][img]/wwwthreads_images/icons/crazy.gif[/img][img]/wwwthreads_images/icons/crazy.gif[/img]
post #7 of (permalink) Old 03-02-2002, 09:32 PM
Is it a serpentine belt? When it is cold outside the belt on my 460 Ford will sound like a bird until it warms up.
Good Luck!
Kriss
post #8 of (permalink) Old 03-08-2002, 04:40 PM Thread Starter
Nope, its not the serpentine, just got a new one and this happens AFTER driving on the freeway for about 30 minutes.
Ill figure it out.. and yes PARAKEETS!
94 ZJ
48 CJ2A
