best D44 for rear of 87YJ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-24-2002, 06:38 AM
sas87yj
i did a search but didn't see the answer-
which donor would be the easiest swap?
thanks,steve
post #2 of (permalink) Old 02-24-2002, 06:58 AM
Re: best D44 for rear of 87YJ?
I bought a junk 87 Grand Wagoneer. I thought it had a Dana 44 rear but after removal and rebuilding time came it was an AMC model 20. The front was a Dana 44. The front after a bunch of repairs bolted right into my 93 YJ. The rear is taking some work. ie moving spring perches, shock mounts and it had a bad seal on the outer wheel bearing which spoiled the brakes big time. I am installing the rear today. I believe some of the 87 and earlier Grand Wagoneers had a rear Dana 44. I have a 89 Grand Wagoneer for sale but I am not sure what that has in the rear. I can check if you think you can find a junk where you are.
So little time, So many trails.
post #3 of (permalink) Old 02-24-2002, 07:17 AM
sas87yj
thanks for the info.
i see this add in phx rag:
SCOUT parts Dana 44 front & rear axles, discs front, drum rear, $995/pr. Auto trans w/Dana 20 transfer case, pwr steering pump. (602)694-6565
maybe a scout donor will work? is $450 ea a little high?
guess i am looking for the same length axle as my 35 and one that will match up close as possible, drum brakes, etc. i plan on moving the spring perches to get rid of my 12* shims. still will keep the SUA configuration.
post #4 of (permalink) Old 02-24-2002, 07:21 AM
I paid slightly less than that. I bought the whole Wagoneer for $25 and then another $25 to get it ramp trucked to my house. My buddy gave me $25 for the carb and electronic ignition for his 83 CJ with a 360. I used the power steering pump, front and rear axles so far. We decided to pull the motor, trans and t/c and save it.
post #5 of (permalink) Old 02-24-2002, 07:55 AM
sas87yj
yep- you did alright on that deal
guess i just answered my own question:
The XJ and MJ are/were available with a Dana 44 with the heavy duty towing option or metric ton option. I'm not sure if the XJ always came with a Dana 44 when the towing option was ordered. The axles will interchange between the models and use a 5 on 4.5" wheel bolt pattern. This axle could also be a good low buck swap for a Wrangler YJ, but the sping perches would need to be moved. The shafts are one piece and 30 spline.
post #6 of (permalink) Old 02-24-2002, 08:08 AM
That's too much. I paid $400 for the pair, bought brand new brakes (calipers,pads,rotors,drums,shoes,wheel cylinders,hardware kit) for just under $300. That save you almost $300 - the price of either a locker or a set of gears.
I'm boycotting sigs. If ya wanna see what I have, check my profile.
AllLockedUp is offline
post #7 of (permalink) Old 02-24-2002, 08:26 AM
elusive's Avatar
no to sound like a 60 60 60 guy, but for about $300 you could get a narrow 14 bolt with 4.56 gears and it would darn near bolt right in..
~~Elusive~~
everything good in life is round, breasts, halos, and headlights
http://www.jeepgod.net
elusive is offline
post #8 of (permalink) Old 02-24-2002, 08:38 AM
How about the ford 8.8" rearend out of an explorer? It's 5 on 4.5 bolt pattern to match your front end,and it has disk brakes.
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
post #9 of (permalink) Old 02-24-2002, 11:13 AM
sas87yj
this looks like WAY too much
$700 or $600 & your stock 3.55 geared axle
Well I am going to de mod the XJ some to sell it faster & cheap. I
have my D44 with a brand new lockright (less than 1000 miles) on it.
The price is $600+your stock 3.55 geared axle or $700 with out your
axle
i do have the 3.55 35 but $600 too much.
post #10 of (permalink) Old 02-24-2002, 05:40 PM
the best fitting dana 44 rear is one out of a XJ, same width and same bolt pattern, just need to re-do spring pearches and mounts........BUT good luck finding one and they do cost more than wagoneer or scouts 44's
ya, a 14-bolt is very similiar to a 44 [img]/wwwthreads_images/icons/smile.gif[/img], i hear some folks are running them little 60 rears these days
<font color=red>3/4tonYJ</font color=red>
http://www.geocities.com/yj3qtr_ton
"Sept 11th 2001" will not be forgotten
3/4tonYJ is offline
