New 2100 bogs-help! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-15-2002, 02:31 PM Thread Starter
New 2100 bogs-help!
Just got done w/ the 2100 swap. Rebuilt the carb, put on, adjusted the mixture, cranks and idles like new. When I went for a test drive, it bogs horribly! If you get on the gas heavy, it seems to run ok, but let off and it bogs again. It almost kills the engine. Let off the pedal, it comes back up and idles fine. Vacuuum leak? Pump rod in wrong hole? What??? I'm going out to check some more things and I'll check back later! Thanks!
Greg
CJ7GREG is offline
post #2 of (permalink) Old 02-15-2002, 02:39 PM
Re: New 2100 bogs-help!
just for something to start with...sounds like an accelerator pump problem. either too much fuel, or not enough. i guess not enough. matt
jeepnmatt is offline
post #3 of (permalink) Old 02-15-2002, 03:34 PM Thread Starter
Maybe I need to move the pump rod to another hole??
Greg
CJ7GREG is offline
post #4 of (permalink) Old 02-15-2002, 05:05 PM
Are you using ported vacuum for your distibutor's advance? Just a thought. If it idles well, it's not a problem with vacuum leaks. I have my accell pump set up with it second hole from the bottom on the lever at the throttle shaft. There is also the lever at the pump itself you can play with.
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
post #5 of (permalink) Old 02-15-2002, 10:05 PM Thread Starter
The dist. is running off the only vac. port on the carb. I don't know if it's ported. How do you tell? If it's not, and it's the only one I've got, what then?
Greg
CJ7GREG is offline
