Body Lift Question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-13-2002, 10:03 PM
CJ Bob
Body Lift Question
I have been using a home made body lift made out of boat rollers but just got a Performance Lift. Question is the way I understand the instructions is that you just set the blocks in between the mount and the body, and take out the upper have of the original body mounts and just use the lower one under the mounts is that correct? When I installed the home made ones I just set them on top of the original ones. Thanks.
83 CJ7--4" Lift, 1" BodyLift, 33", 4.56's, Superior Axles, Rear Detroit Locker, Front PowerTrax No-Slip, X8000I, 258, HEI, MC 2100, Dana 300 Twinstick, York OB Air, Arizona Driveline
post #2 of (permalink) Old 02-14-2002, 01:26 AM
Re: Body Lift Question
I am not familiar with the exact lift you are using but if is like the daystar lift(replaces mount with 1"(or what ever height you are lifting) bushing. and not a puck on top of original rubber bushing, then you just pull the old rubber bushing out and pop in the new one.
wham bam thank you mam.
good luck
tony
79 CJ 5, 258, dana 30, model 20, T18, dana 20, 2.5" rancho lift, 1" shackles
tonyscj5 is offline
post #3 of (permalink) Old 02-14-2002, 10:00 AM
NO! Keep your original body mounts just like they are and set the body lift puck on top of the body mount. The body lift puck should be between your original rubber or poly upper body mount and the bottom of you tub. So starting from the top it will be sheet metal, body lift puck, body mount, frame, bottom body mount. Hope this makes it clearer than those instructions. Later, Casey
Click for info: "1st Annual Anniversary Trail Ride Weekend" in Gulf Breeze, Florida!
http://www.extremetrails.com
