YJ clutch - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-09-2002, 04:21 PM Thread Starter
Novice
YJ clutch
I got in my jeep and the clutch has no pedal!! The fluid is full, no leaks under it. It was fine when I parked it...2 months ago. The clutch plate only has 9k miles (easy miles)any Ideas?????
88yjduck is offline
post #2 of (permalink) Old 01-09-2002, 04:31 PM
Re: YJ clutch
Most likely it's the infamous slave cylinder inside the tranny. Try bleeding it first though, you will find the bleeder valve on the passenger side of the tranny on most YJ's, just loosen it a little till it starts to drip (slowly) then get out from under your jeep and fill the resovour till full, press clutch pedal and refill again, repeat about 4 times till you bleed out all the old fluid, finally fill reservoir and run under jeep and tighten bleeder. Now feel clutch pedal. If it has presure then test drive it (slow). If it doesnt work then chances are it's the slave cilynder, but before you do that I would replace the little master cylinder first being that to replace the slave you would need to drop the tranny to get to it. So to recap, bleed, test, if ok now then great. If not replace master cylinder, if ok now then good. If not then $hit! Replace slave cylinder.
post #3 of (permalink) Old 01-09-2002, 07:46 PM
sas87yj
Re: YJ clutch
my 87 bleeder is on the drivers side- whatever. i agree to bleeding it first- it's free and easy. could be air in the line. the master is around $80 and it could be a candidate also i agree. take the master off- it's easy and take it apart- easy again. i've seen the "plunger" get hung up inside where it depressed but did not return- got stuck. then all you have to do is free it up, clean and re-assemble. you could fix this at no cost in a couple hours. OR.........the slave could be at fault which is a good size job to drop the tranny/transcase. do the easy stuff first.
