-   -   Rear Main Seal Leaking....pointers? (https://forums.off-road.com/jeep-short-wheelbase/101945-rear-main-seal-leaking-pointers.html)
JeepnGreg 01-08-2002 10:49 PM
the rear main seal on my jeep is leaking.....though i am going to check really carefully to make sure its not my Valve cover from the back.
does anyopne have a step by step guide for dummies on replacing the rear main seal? heck if someone has pics of the process that'd be nice too.....
Im pretty slow so leave no detail to my imagination. Andy from the Board here "Jeeper99XJ", said he'll help me out and we can do it at his place, but i just want to mkae sure we do it right so we dont have to do it more than once.
Thanks all!
Greg
<font color=red>Jeep'n Greg</font color=red>
1985 CJ7 not in pieces anymore! Woohoo!
TiminMb 01-08-2002 10:59 PM
Re: Rear Main Seal Leaking....pointers?
Remove crossmember, starter, oilpan. Loosen all main bearing cap bolts and loosen the caps to allow crank to drop down a tiny bit. Lube the new seal. Apply rtv only at the edge of the rear cap. If you buy fel pro rear main seal it will come with instructions. Did I mention oiling the part of the crank that touches the seal so that the seal doesnt run dry to begin with?
Tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
**DONOTDELETE** 01-08-2002 11:27 PM
I recently did the same thing and the bits of advice I got from the board were invaluable. The first thing to do, is get 2 new rear main seals from the parts house. Reason being, if you botch the first one, you have a second one ready. Often times, when you install them, it's easy to shave some of the rubber off of them, in which case they won't seal. The next biggest suggestion is get the 3M Weather Strip/Gasket Maker (Gorilla Snot) for sealing your new pan gasket and some permatex high tack gasket sealer. Levy or Ozark gave me that advice and it worked like a champ.
Things I did for ease of access:
Jacked up the rig, put stands under the frame towards the front and removed the tires for ease of access and freedom of movement.
Next thing you will have to do, assuming you have the 258 and have drained the oil and pulled the oil filter, is to put a piece of 2X4 and a jack under the bell housing, jack it up a little to take the weight off of the motor mounts. You will have to remove the passenger side motor mount to get to one of the pan bolts (there is no way around this if you have the I6)
Pull the pan,if it's been a while since it's been down, you may need a rubber mallet to pursuade it to come off. Once off, loosen your oil pump pick up and turn it out of your way. Loosen the rear 3 or 4 bearing caps and remove your rear cap completely. (The reason you do this is to let the crank hang a little at the back... we are talking fractions, just so you can get the seal out of the block)
When replacing the seals, use a little liquid dish soap to install. Replace the seal in the bearing cap. Take a brass punch and tap out the seal that's in the block. (Make sure not to tear up the journal) Once that seal is out, put some soap on the back side of the new seal and a little oil on the crank side of the seal and slide it in. I found that this takes patience and steady pressure not to score any of the rubber off of the new seal. If you do, don't sweat it, just insert it all the way and remove it. You will have lubed the area a little and will now know what you need to do to get the second one you bough in place without tearing it up.
Once that's done, put a tiny amount of silicone on the back side of the bearing cap (behind the seal tranny side), re-torque your bearing caps to specs check all of them front to back. Put your oil pickup back in place and re-torque.
Hopefully you pan doesn't need as much attention as mine did, but make sure it's nice and clean as well as the block side mating surface. Paint the high tack on the block and position your gasket. Use some of the gorilla snot for the front and real seals. Next, put a healthy coat of the gorilla snot around the actual oil pan, heavy at the corners, front and back and then put the pan on. Use a hand held nut driver and tighten the bolts up. Don't over tighten or it will force the front seal out and blow oil everywhere. You just want this hand tight. After 100 miles you will want to retighten them by hand only.
Redo your motor mount and anything else you did for the prep and all should be good.
Good luck and sorry for the length of the post. This is about as step by step as mine was and I appreciated the help from the board. It made it a lot easier.
BentMetal
83CJ7 definitely broken this time :(
firetruck41 01-09-2002 02:09 AM
Great advice, Bentmetal. This is basically what I did, it took some "persuading" to get the upper half seal out, but after about five minutes with a punch it came out. I found out that my 258 only had 1 of the 3 bolts holding my engine in on the driver side! Guess that was the good thing about having to change the rear main. Good luck.
Ben
1982 CJ-8 Scrambler, 258, T-5, D300, 31x10.5, basically stock
**DONOTDELETE** 01-09-2002 02:26 AM
Do make sure it isn't the valve cover. I swore mine was the rear main, but I did the valve cover anyway and it fixed the leak. I've never done a rear main seal but I imagine a valve cover is a whole lot easier.
David Sanders
http://www.geocities.com/david_sanders_79/jeep.htm
